Results 1 to 2 of 2
    New ROGer Array
    May 2015
    1
    G501 RAM Upgrade: Max Possible?
    Haven't been able to find a definite spec for this... its showing that its got a 16GB installed with 3 empty slots... Should I assume that I can add 3 more 16GB RAM for up to 64GB? Or am i limited to 4 8GB slots?
    Any help would be great! Thanks!
    ROG Member Array
    Feb 2015
    14
    There is only one ram slot inside, 8 gigs glued to the board and 8 gigs in the slot, can't go above that
Tags for this Thread
