Results 1 to 8 of 8
    ROG Member Array
    May 2014
    9
    Upgrade Advice for my current system
    Hello guys,
    I have some kind of a funny problem, I need to spend around 1700€ in 2 months for my PC or someting else.
    So what would u guys recommend for my current rig?
    CPU: intel i7 4930k
    Mobo: Black Rampage 4
    GPU: Asus 780ti DC2OC
    Ram: 16 GB GSkill Ripjaws @ 2400mhz
    PSU: 850W Platinum beQuite Dark Power Pro 10
    Case: Thermaltake Core V71 I like it but, the stock chassis fans are way too loud (3x 200mm fans) I want to change them and add 1 fan. Any tipps on these things?
    Cpu cooling: H100i Corsair
    256gb SSD Samsung evo pro and 1 TB HDD dont need more.
    Im currently using a 1080p display I want to upgrade to 1440p or 4k.
    ROG Guru: Yellow Belt Array Deon017 PC Specs
    Deon017 PC Specs
    MotherboardASUS Rampage IV Extreme Black Motherboard
    ProcessorIntel Core i7 4960X Extreme Edition
    Memory (part number)Corsair Vengeance Pro CMY32GX3M4A2133C11 32GB
    Graphics Card #1Asus Poseidon GTX 980Ti
    MonitorAsus Rog Swift 27" 3D Monitor
    Storage #1ASUS RAIDR Express 240GB PCI-E SSD
    Storage #2HDD: Intel 520S 240GB SSD
    CPU CoolerEK Supremacy Elite CPU Waterblock for Intel 2011
    CaseCorsair Obsidian 900D Super Tower Case
    Power SupplyCorsair AX1200i Digital ATX Modular Power Supply
    Keyboard Logitech G19s Gaming Keyboard
    Mouse Asus ROG Gladius
    OS WIN 10
    Network RouterAsus RT-AC3200
    Deon017's Avatar
    Aug 2013
    147
    If just to spend money, then go for it, but performance wise I would just do the PSU and sli 2 x 980's or Titan X. The performance on the new 5930 is not really going to give you the upgrade you would expect, for the money you are going to spend.
    ROG Guru: Brown Belt Array Antronman's Avatar
    Dec 2013
    29
    1,374
    Don't buy a Titan X unless you have the money to buy two and a 4k panel.
    Second 780ti.
    Or wait for Q2 this year for R9 390x and get two or one of those.
    Say hi to the next generation.
    Peace is a lie, there is only Passion
    Through passion, I gain strength
    Through strength, I gain victory
    Through victory, my chains are broken
    The Republic of Gamers shall free me
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,129
    the 980 is coming out as 980TI whit 6gig mem.
    but when im not shure.
    that is IF you are going to upgrade it.
    the 4K panels are locked to 60H.
    1440P you can get to 144HZ whit g-sync.
    ROG Member Array
    May 2014
    9
    So, nothing is really useful for me at the moment except maybe a 2nd cheap 780ti... well thank you guys, Ill try to wait for the new cards...hopefully they dont suck .
    You guys got any idea on the 200mm fans?
    Deon017 PC Specs
    OS WIN 10
    Deon017's Avatar
    Aug 2013
    147
    [QUOTE=You guys got any idea on the 200mm fans?[/QUOTE]
    What about then, Benfenix - aerocool -thermaltake - nzxt, they all have them, Benfenix has a Spectre Pro that looks good
  7. #7
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    I would buy a second GTX780Ti, too. Beware that you may require a PSU upgrade with it (or you may not, it looks like a sorta borderline judgement call).
    I've found NZXT 200mm fans to be very quiet, but haven't tried any other 200mm fans.
    If your fans keep blasting at full speed while your temps are low then you might do better with a fan controller.
    Another reasonable (bang for the buck) upgrade would be installing a second identical Samsung SSD in striped RAID - whenever you see one on sale.
  8. #8
    Aug 2011
    243
    6,129
    well a SSD for games will boost your load time on it ( for example FPS games ) between maps/loading time.
