Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    May 2015
    6
    Lightbulb Power Management Tool/Utility
    Hi co-Asus ROG owners,
    can i have your suggestion about my query.
    I have asus rog g501, and i want to have a power management tool that will stop the charging when my laptop's battery percentage goes into 50 or 60%.
    do asus have this kind of software? or any 3rd party apps. kindly pls help me.
    Thanks...
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hello gambas43 and welcome
    Please don't make multiple threads about the same topic, the forum moderators frown on that.
    Any particular reason why you don't want your laptop battery fully charged?
    ROG Member Array
    May 2015
    6
    because i want to get my g501's max performance on gaming all the time , so i will not be worried to know if my battery is fully charged already while im playing. my laptop's gaming performance drops when it's on battery mode even i choose the power option "high performance" it helps but my fps in nba 2k15 drops significantly and its not smooth as when my laptop is plugged in.
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    It's best to let it plugged in when playing games.
    Have a read through this it's about limiting battery charging.
    http://pc.net/helpcenter/answers/cha...ging_threshold
    ROG Member Array
    May 2015
    6
    so its ok to let it charge to full 100% while im playing games?
    does it not make the temperature on my laptop go mad?
    Thanks for the reply
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    IYeah it's ok to let it plugged in, once the battery is fully charged it should sit idle. Or if you are able to remove the battery you could do that too.
  7. #7
    ROG Member Array
    May 2015
    6
    it will not go down to 99% and charge the battery all over again?
    sorry for my question just needed to ask.
    Thanks.
  8. #8
    ROG Guru: Orange Belt Array C4RN1 PC Specs
    C4RN1 PC Specs
    Laptop (Model)G51VX, G71G, G73, G74SX, G53SX, G53JW, G46VW, X501A, X401A
    MotherboardASUS M5A88-V EVO
    ProcessorAMD FX-4350 Vishera Quad 4.2GHz
    Memory (part number)16GB 4x4gb Mushkin Black Line
    Graphics Card #1HD Radeon 5970
    Graphics Card #2HD Radeon 5970
    Graphics Card #3HD Radeon 5970
    MonitorSamsung SyncMaster SA450 x2 (Provided by HP)
    Storage #1Corsair Force GT 120GB SSD
    Storage #2Western Digital 1.5 TB HDD
    CaseAntec 900
    Power SupplyKingwin Lazer 1000W
    Keyboard HP OEM
    Mouse Logitech Anywhere MX
    Headset ROG Orion
    OS Windows 7, Windows 8.1
    Network RouterLinksys E-1000 (DDWRT)
    C4RN1's Avatar
    Jul 2012
    16
    262
    Laptop charging systems are designed to quit charging the last 5%. Your charging cycle will charge anywhere from 1%-95%. If you unplug your computer for a couple minutes and get it under 95% it should charge back up to 100%. Though if you are at 97% and plug it in, the computer might say "plugged in, not charging" which is completely normal.
    Also if you keep the battery plugged in all the time it's going to last just as long as if you used the battery normally. If you want to preserve the battery you can remove it from the laptop, though it's kind of pointless having a laptop without a battery.
    Just stick with the way it was designed and you'll be fine.
  9. #9
    ROG Member Array
    Jun 2015
    5
    So is it safe that if my ASUS G501JW battery stops moving at around 88-90 percent? but it still says "plugged-in, charging" I just bought this laptop yesterday. I'm kinda scared because this is my first time encountering this problem.
  10. #10
    ROG Member Array
    Jul 2015
    11
    7
    Question
    Joining the request, I really miss the Energy Management tool I had with Lenovo's laptops.
    99% of the time my laptop is plugged in. It's not good for lithium batteries to be all the time in extreme percentage (neither low or high), the best for the battery health is to be around 50-60 percent.
    Any tool for that please?
    Nate152
    They don't provide any solution in this link, they say "there is no way to modify the battery charging threshold"
Tags for this Thread
