Help with GPU Tweak :)
TiagoRocha89
Hi everyone,
I'm new to PC Gaming, and I just got a Asus GeForce GTX 750 Ti. It came with a GPU Tweak, I installed, and has a few profiles, one for Games.
I can change the Boost/Memory Clock, or even Speed up the fan. The thing is... What's the correct set up? My old Graphic card didn't had any of these options.
I already played some old games like Timeshift, Kane & Lynch 2, runs pretty well, I didn't noticed anything strange. But I may be wrong.
What do you guys think? 🙂
Nate152
Hello TiagoRocha89 and welcome
GPU Tweak is an overclocking tool you can use to squeeze out more performance from your 750ti. There are no wrong settings, you can overclock it as far as you want....
To a point that is, if you overclock the boost too far the driver will crash, then you just back it down a notch or two. If you take the memory too far you will start to get artifacting or the driver will crash, then just back it down a notch or two.
You can set a fan curve to ramp up the fan speed determined by the temperature.
GPU tweak is a neat little tool, have fun playing with it and your 750ti.
TiagoRocha89
Hello Nate152, thanks for clear things up for me!
I might set the fan up a little bit, just in case. But the other settings, I'll leave them be, as I haven't had any issue yet 🙂
Thanks for help 🙂
