Results 1 to 2 of 2
    New ROGer Array
    May 2015
    3
    case build ** disign meets funktion **
    self build asus x99 rampage v , g skill ripsaw 32gb men , intel 5930x , antec 1kw 80+hpc psu , Scythe Kama Panel 3.1 , asus dvd hd16
    for case build i use wood , plexiglas and lian li parts (drive bay and mb tray) and a old cheep case , alaska sound proofing.
    lian li 8000 mb tray , van grill , feet , hdd drive bay 2x4.
    the side panels slide out for easy access.
    vid card asus r2390 cu3
    ssd pci intel 750 400gb
    cpu cooler nzt x41
    asus hd16 blue ray burner
    New ROGer Array
    May 2015
    3
    top pic
Tags for this Thread
