Results 1 to 10 of 12
Thread: Gtx 970 low frames
05-23-2015 05:12 PM #1
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 6
Gtx 970 low frames
Hi, I recently bought the ASUS Strix GTX 970.
Is it normal that in Batman Arkham City that i'm getting around 50 fps on maxed settings?
Or Borderlands 2 frequently drops to 35 fps?
I had someone tell me that my PSU could be limiting the card, even though it reaches 98% usage.
But for the point of information, I have a Corsair CX 600w PSU
I am also running an i5 3340 @ 3.3 Ghz
Thanks in advance
05-23-2015 08:57 PM #2
Nate152 PC Specs Motherboard ROG Maximus IX Code Processor i7-7700k 5.2GHz Delidded Memory (part number) 16GB G.Skill Trident Z 4025MHz 17-17-17-39-2T Graphics Card #1 Titan Xp - EKFC waterblock Graphics Card #2 Titan Xp Sound Card ROG SupremeFX 2015 Monitor HP ZR30w Storage #1 Toshiba OCZ VX500 256GB CPU Cooler Swiftech Apogee GTZ Case Thermaltake Armor+ VH6000 Power Supply EVGA Supernova 1600w Titanium Keyboard Cyberpower Skorpion K2 Mouse Razer Basilisk Headset Sennheiser HD6XX / Modmic 5 OS Windows 10 Home 64 bit Accessory #1 Asus optical drive Accessory #2 Koolance ERM-2K3U
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
Hello hjmhkh
Welcome to the ROG forum !
You have your gtx 970 maxed out with 98% gpu usage. What resolution are you gaming at and are you using Antialiasing?
05-23-2015 09:55 PM #3
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 6
Well it might hit 100% and I just don't notice, I mean it's obviously not throttling to 50 or something.
My resolution is always set to 1080 and I usually have AA on MSAA x8.
Is it that i'm expecting too much from the card and should knock down AA?
05-23-2015 10:12 PM #4
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 6
In borderlands 2, I put every setting on the lowest it could be and it's the same. Drops to 35 and frequently below 60 fps
05-23-2015 11:26 PM #5
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
yeah back off the AA 8x is too much, try it at x2 or x4 this will get you more FPS.
05-23-2015 11:48 PM #6
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 6
People are telling me that my poor quality psu is causing the problem
05-23-2015 11:56 PM #7
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
No I doubt it's your psu, the gtx 970 calls for a minimum of a 500w psu.
Have you lowered the AA? AA puts a big hit on performance.
05-24-2015 12:01 AM #8
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 6
well i put everything on borderlands 2 on low/off and i still get the performance hit
05-24-2015 12:08 AM #9
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
Have you tried updating to the latest NVidia driver 352.86?
If you update to the new driver here is what I do. After the license agreement click custom/advanced install. Uncheck everything except the graphics driver and PhysX driver then just below check the only box that says perform a clean installation.
I don't use Geforce experience or the NVidia audio drivers.
Give this a try and see if it helps performance any.
05-24-2015 01:10 AM #10
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 6
I tried that earlier, didn't do anything :/
