Case Ideas
HeyItsRon
Hey Everyone!
So I build my first computer about4 years ago, and recently I have gotten the itch to rebuild/build a new computer by swapping out some parts with newer ones and using some others. I would like to add a custom loop to the build, but am struggling to find a case that meets my criteria. I think finding a nice case has been harder than picking the parts out. Anyways, I am looking for a case that has a large side window panel to where a good view of the insides including the entire loop including reservoir can be seen. I am going for a white/red build so a white case would be ideal. HOWEVER, I have no problem buying a black case and doing some work and just repaintint it white.
So any suggestions on cases is greatly appreciated.
This is a list of parts that I have selected for my new build: http://pcpartpicker.com/p/ytzvQ7
If you have any suggestions on switching a part out with a better part or because it may not work with the water build, please I am open to any and all suggestions.
Again, thanks for the help!
4 REPLIES 4
Ntwlf
Level 12
Hello HeyItsRon, and welcome to ROG.
Here's a case that you may like...Cooler Master Storm Stryker.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119260&cm_re=CM_Storm_Stryker-_-11-119-260-...
Here's a club thread dedicated to the CM Storm Trooper & Stryker cases.
http://www.overclock.net/t/1104349/the-official-cooler-master-storm-trooper-storm-stryker-club
You'll find lots of info about what members have done with these cases.
I noticed in your PartsPicker list, that you have (2) 8GB Kits of G.Skill Ripjaws X Series (already purchased). You'll probably have problems with the 2 kits in one system. Have a read here, as Raja explains it best.
https://rog.asus.com/forum/showthread.php?57038-Don%92t-combine-memory-kits!-The-meat-and-potatoes-o...
And/or here, as I tried to explain in Layman's terms.
https://rog.asus.com/forum/showthread.php?61291-32GB-Memory-Kit-arrives-in-2-packages
Enjoy your new build.
Nate152
Hello HeyItsRon
Welcome to the ROG forum !
Yep as Ntwlf says a single 16GB kit is the way to go to avoid potential problems and headaches.
For cases I been liking the caselabs pc cases. They cost a little more than most other cases and are customizable. (If that's a word)
You can have it done in white too !
http://caselabs-store.com/
HeyItsRon
Thanks for the quick replies, I've had the two kits in my current build for over a year now and haven't come across any problems (maybe I got lucky). But with the replacement of the mobo and cpu, I might have problems and if I do, at least I know where to look first haha. What have you guys heard if anything of the Enthoo Primo/Pro/Luxe?
Nate152
The ethno primo is a good case too, there is a lot of room and options for water cooling.
Here is a review from tech powerup.
http://www.techpowerup.com/reviews/Phanteks/Enthoo_Pro/1.html
