Results 1 to 3 of 3
    ROG Member Array larsiano PC Specs
    larsiano PC Specs
    MotherboardROG RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9-9940X X-series
    Memory (part number)Corsair Dominator Platinum RGB 32GB DDR4-3600 CL16 quad kit
    Graphics Card #1ROG GeForce RTX 2080 Ti Strix OC 11GB
    Sound CardASUS Xonar Essence One DAC
    MonitorROG PG348Q + PG279Q + Dell U3011
    Storage #1Samsung 970 Pro 1TB
    Storage #2Intel 750 Series 400GB PCI-e 4x
    CPU CoolerCorsair Hydro Series H115i RGB Pro Platinum
    CaseCorsair Obsidian 750D Airflow Edition
    Power SupplyCorsair AX1600i Titanium
    Keyboard Corsair K70 RGB MK.2 Low Profile Rapidfire
    Mouse Asus RoG Gladius II Wireless
    Headset Sennheiser HD 650
    Mouse Pad Asus RoG Balteus Black
    Headset/Speakers Bose V30
    OS Microsoft Windows 10 Pro 64-bit
    Network RouterISP
    Accessory #1 Corsair Gaming ST100 RGB Surround 7.1 Black
    Accessory #2 5 x Corsair ML140 Pro RGB 140mm Black
    Accessory #3 Corsair Commander Pro + 4 x RGB LED Strips
    larsiano's Avatar
    Jan 2014
    21
    Question [R4BE] Top PCIE slot not working with GPU
    Ive tested two different PCI-e 3.0 cards on my replacement R4BE mobo. Both cards work in other slots except the top slot. In the top slot the system will not boot and the VGA led on the motherboard is active. I have checked the PCI-e switches on the motherboard and all are turned on. As i tought the top slot would function just like any other slot this is very strange? Tested with no overclock (only memory @ XMP speed normaly) at all to no avail. If i put my PCI-e SSD Drive in this slot it does work funny enough?
    Specs:
    MoBo: Asus R4BE (BIOS 0801)
    RAM: 2400MHZ quad kit G.Skill RipjawsZ 16GB
    CPU: 4960X Intel + Corsair H100i
    OS: Win 7 UK x64 Ultimate
    GPU: Asus GTX980 Strix (also tested with 780GTX OC Asus)
    HDD: OCZ RevoDrive 3 X2 240GB PCI-e
    PSU: Corsair AX1200i Digital Platinum
    larsiano PC Specs
    Network RouterISP
    larsiano's Avatar
    Jan 2014
    21
    maybe i should add:
    -there is no damage to the top PCIE slot
    -It has never worked in this slot
    -tested with different memory, psu and gpu's
    -removed the mobo from the case
    Note: also i am a professional technical support rep. and have troubleshooted a lot of hardware in my time. The only question i have here seeing the complexity of the R4BE if there is anything else that could solve this problem without having to RMA the board again?
    ROG Enthusiast Array jaggerwild PC Specs
    jaggerwild PC Specs
    Laptop (Model)NONE
    MotherboardMANY
    ProcessorMANY
    Memory (part number)MANY
    Graphics Card #1MANY
    Graphics Card #2MANY
    jaggerwild's Avatar
    Jul 2013
    65
    Sense your a PROFESSIONAL Technician you have also tested a different GPU?
    Asus X79 DELUXE
    3930K WATER
    2X Intel 520 Raid o
    2X GTX 780ti DCII OC WATER
    16 GB G skill 2133
    Corsiar AX1200
    Acer 24" 1080
    Swiftech MCP655 Vari
    HWlabs 3/120
    Asus DVD
    BLIND BIOS FLASH LINK http://rog.asus.com/forum/showthread...BIOS-FlashBack
