Results 1 to 4 of 4
    New ROGer Array
    Jun 2015
    3
    Fast switch between 120 ULMB and 144 GSync
    Is there a faster way to change between the 120 Hz ULMB mode and 144 Hz Gsync mode then going to Nvidia settings, changing Hz and enabling/disabling gsync, then enabling/disabling ULMB on screen menu.
    I play CS Global Offensive in 120 ULMB, and all other games in 144 Gsync. I change multiple times every day, and the process is quite tedious.
    New ROGer Array
    May 2015
    4
    Yeah i wished they had something like this too
    Because I got tired of doing it so just left it in 144 hertz g sync mode
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Can't you set these preferences in per-application profiles for CS:GO (and other games)?
    New ROGer Array
    Jun 2015
    3
    Quote Originally Posted by Korth View Post
    I dont know? Please explain how
Tags for this Thread
