Heyo all!
I have bought a brand new 960 yesterday to finish my build that was running without GPU for a few weeks. Everything works fine, as long as no GPU is installed, but I get stuck as soon as I install it.
Specs are: Maximus VII Impact, 4790k, Gigabyte 960 G1 Gaming, Corsair AX760i, Corsair H75. That should cover everything important.
What I know: The System without GPU works fine. The PSU is supplying power, I tested the connectors with a multimeter. The GPU works, I was at the store today and on their system it worked no problem.
What I have done: Check the connections of everything, PCIe slot, power cables, I even reseated the CPU to check for bend pins...
If anyone can help me that would be wonderful.
-LeeDoe
