Results 1 to 5 of 5
    muthurs
    Guest
    G74SX Case Problem.
    Well... my laptop has a new issue and that would be that it is making a lot of noise when I'm touching the wrist rest on the right side where the model sticker is. I don't know what to do. Can I fix this anyhow?
    ROG Guru: Black Belt Array
    Oct 2011
    31
    2,916
    Do you mean the top cover has some "give" in that spot and pressure makes it wiggle a bit?
    muthurs
    Guest
    I mean that on the right side of the touchpad/ left side of the sticker there is something like a gap which unde pressure makes a CLACK noise that drives me crazy.
    muthurs
    Guest
    http://www.youtube.com/watch?v=1Y3Ja...&feature=feedu that's the clack I'm talking about.
    Oct 2011
    31
    2,916
    Along the front edge, the top cover has a lot of attachments to the chassis. There are little plastic clips all along the edge, and then 6-7 screws to secure it. If any of these are not snug, it'll create a gap and the top cover has some wiggle. Try peek along the gap with a flashlight to make sure nothing is actually stuck in there.....there's really nothing in that area except an audio cable, and it's unlikely that got so dislocated.
    After confirming that there's no physical obstruction, squeeze the area ((i.e., squeeze the top cover and chassis together) to see if you can get the clips to snap. They have a very positive "click" when they do, so you'll know when they've closed.
    TO check the screws that secure that area, turn the laptop over and remove the back panel. (Turn it off first! ) Tighten the three circled screws, two of which are for the Drive 1 caddy:
Name:	Top cover attachment.jpg
    EDIT: Just to be clear, most of the hard drive caddy screws are also chassis screws....they must be present and tightened to fully secure the top cover along the front edge and in the palmrest/touchpad area. If any of them are not present, that area can feel noticeably "loose."
Similar Threads
  1. Just got my G74SX - One problem
    By thalador in forum ROG Gaming Notebooks
    Last Post: 06-12-2013, 07:33 AM
  2. G74SX Case?
    By Jassper in forum ROG Gaming Notebooks
    Last Post: 12-16-2011, 01:08 AM
  3. First problem with the G74SX that might turn into a big problem
    By Boosted_R in forum ROG Gaming Notebooks
    Last Post: 11-11-2011, 07:00 AM
  4. G74SX-3DE IR/ORG key problem
    By nathalamis in forum ROG Gaming Notebooks
    Last Post: 10-16-2011, 03:41 PM
  5. Fractal Design's new "Arc" Midi Tower case, good case for Modding!
    By MonsterMawd in forum Case Modding & PC Builds
    Last Post: 05-20-2011, 12:13 PM
