Results 1 to 3 of 3
    ROG Member Array
    Jun 2013
    17
    Exclamation No Audio from Mobo (Crosshair V Formula-Z)
    I recently upgraded to this motherboard because I wanted to have what I consider the best. Yesterday, I plugged in my 3.5mm headphones and couldn't hear anything. I checked the Playback devices from within Windows 7, and it did show that audio was being created when tested.
    However, I did notice the option for Realtek speakers was not available. Mind you, the previous mobo was a Crosshair V Formula. I went into Device Manager and uninstalled the Realtek audio driver, and then had it reinstalled automatically from the computer. This gave the option for the Realtek device in the Playback devices area. Although testing showed it getting sound, I could still not hear anything.
    I then went ahead and started uninstalling and reinstalling the drivers for Realtek. I even went so far as to download the latest from Realtek. Neither helped. I lost the option of a Realtek Playback device by reinstalling the drivers. I could only seem to get it to show if I went into the Realtek Manager under the Control Panel and selected AC'97 instead of HD.
    I checked that the HD header was properly plugged in on the motherboard, and it was. The BIOS also had HD audio enabled. I attempted switching the header to AC'97, as well as the BIOS setting, but got the same result.
    Since I had been using only the front panel of my case, I decided to plug in directly to the I/O panel on the back. This too did not work. I have checked with two pairs of working headphones, and I even tried a USB sound device with stereo jacks that allows sound to come through perfectly.
    Is there any other fixes I could try?
    ROG Guru: Brown Belt Array MeanMachine PC Specs
    Laptop (Model)I enjoy my wife
    MotherboardCVI HERO + CVII Hero Wifi
    ProcessorRyzen 7 1800X + 2700X
    Memory (part number)CMD16GX4M2B3000C15 + F4-3200C14D-16GTZR
    Graphics Card #1EVGA GTX980 SC for CVFZ
    Graphics Card #2EVGA GTX 1080 hybrid
    Graphics Card #3GTX 770 for phys x
    Sound CardMB
    MonitorHP w2408h
    Storage #1Samsung 970 EVO 500GB M.2
    Storage #2Samsung 840EVO 500GB and 960 M.2 pro
    CPU CoolerCorsair H105, H110 and H115i
    CaseCorsair 750D and 780T
    Power SupplyCorsair AX-1200i and Antec 850 pro platinum
    Keyboard Logitech K800
    Mouse Razer Mamba
    Headset Corsair Vengeance 2100
    OS W7 Ultimate 64bit and W10 pro 64bit
    Network RouterNetcom Wireless NF18ACV
    MeanMachine's Avatar
    Apr 2014
    126
    1,675
    Hi Heatshiver
    Have you checked in Bios, your settings for SB HD Azalia Configuration? Sometimes when you load an overclock profile they get turned off.
    Also if you update Bios, they can default to being off.
    Onboard Device Config is in the Advanced Menu of your Bios.
    If these are set to enable, including all ASMedia controllers (If usb device) and still do not appear in Playback devices (within Windows) Then I think your Audio chip is not functional and time to RMA.
    MM
    We owe our existence to the scum of the earth, Cyanobacteria
    My System Specs:
    MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
    CPU:
    AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
    Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
    ROG Member Array
    Jun 2013
    17
    Unfortunately, I already went through the BIOS and made sure everything was setup properly...
Tags for this Thread
