Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Member Array
    Nov 2011
    6
    Laptop Asus G53JW-SX082D bluscreen problem after upgrade ssd and ddram
    I upgrade with a KINGSTON SV100S264G ssd and i also put 2x4G Corsair CMSO4GX3M1A1333C9
    i run windows 7 ultimate 64*
    i wonder which could be the cause.
    thanks in advance!
    ROG Enthusiast Array
    Nov 2011
    60
    Did you upgrade both at the same time?
    Did a clean install on the SSD?
    If yes to both, try rolling back to the original RAM memory and see if the BSOD still happens.
    ASUS G53SX
    Core i7 2630QM | GTX 560M 2GB | 8GB DDR3 1333 | OCZ Vertex 3 120GB | Seagate Momentus XT 500GB
    Razer Orochi | Razer Moray | Logitech X-540
    ROG Member Array
    Nov 2011
    6
    Wink Laptop Asus G53JW-SX082D bluscreen problem after upgrade ssd and ddram
    i roll back to the original RAM memory and there is no problems.
    but i feel sorry i can't use my 8Gb RAM because on the official site it says it can handle but it doesn't work with 6GB of RAM also.
    10X for your help Verruckt
    ROG Guru: Green Belt Array fostert's Avatar
    Oct 2011
    54
    706
    Download and burn memtest86+ onto a CD. Boot this CD, and let the tests run on your new memory for a full three passes (will take a while). If **ANY** errors are found, you should be able to RMA your RAM and get new sticks. If any errors are found on your RAM as tested, its likely the RAM causing your BSODs.
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    What is the firmware version of your SSD? See http://www.kingston.com/support/ssdn...0_firmware.asp
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    ROG Member Array
    Nov 2011
    6
    i have the latest firmware D110225a ,it came like this.
    ill check the RAM and ill tell how it was.
    10X
  7. #7
    ROG Member Array
    Nov 2011
    6
    I checked the RAM with memtest86+ and it shows they have 2 errors.
    Ill send them to be replaced.
  8. #8
    Oct 2011
    54
    706
    Yep; 0 zero errors is the only acceptable outcome for memtest with good RAM. Bets of luck with the replacements.
  9. #9
    anankast
    Guest
    G53JW-SX082D suports only 1066MHz DDR3. Your Corsair CMSO4GX3M2A1333C9 is 1333MHz DDR3.
  10. #10
    ROG Member Array
    Nov 2011
    6
    The RAM which came with the laptop it is also 1333Mhz.
Similar Threads
  1. ASUS G53JW problem - white screen.
    By marcin-1981 in forum G Series Gaming Notebooks
    Last Post: 11-29-2011, 08:42 AM
  2. ASUS G53JW Bios Update Problem
    By adramora in forum G Series Gaming Notebooks
    Last Post: 10-27-2011, 06:20 PM
  3. WHY MY G53JW A1 LABELED 6GB OF RAM ON THE LAPTOP READS...
    By KBOOM in forum G Series Gaming Notebooks
    Last Post: 05-19-2011, 06:02 PM
  4. Laptop bag/backpack for the G53Jw-AX1
    By Jack Brown in forum G Series Gaming Notebooks
    Last Post: 03-10-2011, 08:25 PM
  5. G53jw memory upgrade
    By pbot in forum G Series Gaming Notebooks
    Last Post: 01-22-2011, 02:25 AM
