Results 1 to 8 of 8
    zfrenchpig
    Guest
    ATX Power Connectors
    Can anyone tell me why the EATX12v connectors are 8 pin and why I cant seem to find the connector that fits it. My power supply, corsair 1000w doesnt have the same pin configuration, the only way the connector fits is to not plug in the last pin set . this leaves 2 power pins left hanging....Any ideas???
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,887
    It should be either 4 or 8 pin. The 6 pin connectors are for your video cards. You can use something like this below but be aware that it's not the same so be cautious about powering a ton of things from the board alone.
    http://www.amazon.com/EPS-8-Pin-Powe.../dp/B002BFNZAO
    TeamROG Folding@Home Array ottoyu34 PC Specs
    ottoyu34 PC Specs
    MotherboardMaximus IX Hero
    ProcessorIntel Core i7 7700K
    Memory (part number)Trident Z RGB (F4-3600C16D-16GTZR)
    Graphics Card #1ROG Strix GTX1080 Ti OC
    MonitorLG IPS LED 27"
    Storage #1Samsung SSD 850 PRO 1TB
    Storage #2Crucial MX300 525GB SSD
    CPU CoolerCorsair Hydro H115i
    CaseCorsair Obsidian 750D Airflow Ed.
    Power SupplyEVGA SuperNOVA 750 G3
    Keyboard Corsair Vengeance K65
    Mouse Logitech G502
    Mouse Pad Razer Destructor
    Headset/Speakers Logitech Z-2300 2.1
    OS Windows 10 Pro x64
    Network RouterAsus RT-N66U
    ottoyu34's Avatar
    Apr 2010
    805
    Look for the one that 8pin (4+4pin) and should be called EPS 8-pin on the box of the powers supply.
    Brian@ASUS
    Guest
    older or lower powered motherboards use 4 pin connectors. these days boards usually use a 8 pin so they allow you to attached 2x 4 pins together. high watt PSU usually includes a dedicated 8 pin connectors. these 8 pin connectors for the motherboard is different from the 8pin that goes on your graphics card. the connector is designed differently. for the Rampage III Extreme, you are able to plug is 2 8 pin connectors if your PSU provides the option but is not necessary. the second 8pin is there for extreme overclocking and to drive more power to the cpu.
    ROG Member Array
    Nov 2010
    8
    Sorry to hijack this thread, question pertains to the same thread, didn't feal necessary to make a new one.
    I just received my R3E Monday, and got everything working with my i7-950 and all works great. My question is however with power connectors as well. My current power supply, Antec 1000w, has 1 4-pin connector and 1 8-pin connector. Would it be advisable to use both connections, or just use 1 or the other? Currently only have the 4-pin connector plugged in with no problems but haven't done any ocing yet. Would the mobo get to hot with both plugged it? Currently only on air but will be upgrading to liquid colling and ocing to 4ghz+ in the near future.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,887
    I would definitely switch to the 8pin and you should be fine for what you are planning. Someone who knows the engineering of the board (ie Brian) would have to answer whether the board can properly balance 8+4. The board will not get hotter just by having more power available though. This will only be an issue if you actually use the power (over-volting, etc).
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  7. #7
    ROG Member Array
    Nov 2010
    8
    Just what I was looking for thanks, will switch to the 8-pin when I get home
  8. #8
    Brian@ASUS
    Guest
    you are fine with just a single 8pin. the second 8pin for rampage iii extreme is to provide additional power to the cpu when in extreme extreme overclocking conditions. remember the r3e was designed with extreme overclocking in mind. for gaming our formula board will handle it just fine. so again all the additional power options for vga and cpu are not necessary unless you are hardcore overclocking.
Similar Threads
  1. AC Power Supply Problem
    By thumper64 in forum ROG Gaming Notebooks
    Last Post: 12-30-2010, 03:28 AM
