Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Enthusiast Array
    Aug 2011
    38
    [g74sx] Color depth reduced, software problem or hardware damage?
    I've had my G74sx (3D-Display, geforce 560M with 3GB, one HD replaced with SSD) for about three months now and apart from a few crashes I've had no problems with the current machine, or so I thought.
    But today when the BluRay player wouldn't display anything but a black screen I got to wondering about the color depth displayed. A few weeks ago I thought I'd noticed a change in how colors are displayed (various images, including the windows login screen I remembered as 'clean' looking different with less smooth color gradients), but dismissed it as just my imagination.
    So I found myself a site with monitor test images and looked at the gradient section. And indeed what was supposed to be smooth showed banding. I changed to 16bit color depth and back to 32bit with no change. Then I went back to the latest nVidia reference driver rather than the beta driver I'd been using and it got better, but still not completely smooth (of course, it might have been the reboot rather than the driver change). The java script info box on that page says my color depth setting is 24bit, not 32bit like I set it in the display properties (1920x1080, 32bit TrueColor, 60Hz).
    So now I'm wondering, is there any way to more accurately check this and most importantly determine whether this might be some sort of hardware problem?
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    What version video driver are you using currently?
    Launch NVIDIA Control Panel. In "Display - Adjust desktop color settings", in "2. Choose how color is set", how is it configured for your laptop display?
    How is "3. Apply the following enhancements" configured?
    In the Video section, "2. How do you make color adjustments", what is the configuration for your system?
    Screen shots could be helpful in your answer.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    Aug 2011
    38
    I'm currently using the GeForce 285.62 WHQL driver installed with the 'clean install' option.
    Under 'Display - adjust desktop color settings" the "2. Choose how color is set" setting is turned to "Other applications control color settings". ". Apply the following enhancements is set to Digital Vibrance +50%, Hue +0%. Since I haven't changed anything about these I figure they are default settings.
    Under "Video - Adjust Video Color settings" it's set to "With the video player settings".
    I'll see if I can make screenshots that show what I mean.
    Sep 2011
    89
    4,437
    That does look like the defaults. I was hoping your settings were different.
    Here's another thread on this issue: http://www.asusrog.com/forums/showth...light=gradient
    It'll give you some other things to try, but we were unable to resolve that one.
    Are you running the pre-installed Windows 7 OS or have you performed a clean Windows 7 install?
    Aug 2011
    38
    I haven't done a clean install, no. And in the beginning I don't think it was like this.
    A few screenshots ...
    I think it's two separate issues. One is that Aero or whatever's doing the desktop background introduces some sort of compression artifacts. Again, I don't think it has always been doing that (I seem to recall first noticing it after a graphics driver crash, but I can't be sure).
    Clear vertical banding here, though that alone might be just a resolution issue of the image used. What's stranger is that every other band looks like it has a sort of grid pattern in it. No matter how much I zoom in the grid size still remains the same though, so it's not part of the image. It's like the monitor can't display the color exactly so it uses some sort of dithering? I see the same effect in some of the colors in the previous image as well.
    The color transitions in this screenshot aren't always smooth and I think it's the same grid pattern effect in some of the colors that makes it noticeable.
    Aug 2011
    38
    The effect is especially pronounced here, with a pattern of horizontal bands showing that pixel grid.
    Finally this bit of JavaScript claims that color depth is set to 24bits when the control panel says 32bits.
    Hence my question about how to check this for certain. If something screwed up the color depth setting I could imagine that leading to this sort of effect, but I don't really trust either windows or some random script to tell me the whole truth.
  7. #7
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Do you trust Adobe?
    Here's what I get for color in Photoshop CS5 info - Video Mode: 1920 x 1080 x 4294967296 colors
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
  8. #8
    Sep 2011
    45
    As i remember 24 and 32 bits are the same... Just that 32 bits also have alpha or transparency, but you will have the same colors.
    You are having that banding issue with all the images?? Check this ones, the first one is made with 8 bit, im not seeing lines in that one, and the second one is made with 16bit, there i see the lines http://www.megaupload.com/?d=GIK1UGNX
    Really don´t know why this happens, but i see this "problem" in my other pc, in the external monitor, everywhere, even in the television in some chanels. But i remember that if i add like 0,1 of noise to the gradient layer (when i´m working in ps or il) that problem of banding goes away, don´t know why!!
  9. #9
    Sep 2011
    89
    4,437
    In the "List All Modes" screenshot, there is a "True Color (32-bit) 59 hz setting. Have you tried this?
  10. #10
    Aug 2011
    38
    I don't have photoshop but I'll see if I can get it.
    I don't see any real banding in the first image, MPerni, but I do in the second. This strange grid effect does appear in both, though, if only very, very discreetly in the first.
    I've tried the 59Hz setting and the 100 and the 120, but saw no difference (except that 100+ Hz leads to occasional flashes of visual artifacts).
    I also tried booting from an Ubuntu live system cd to see if it was a windows issue, but I'm not entirely sure how to interpret the results. I didn't get this grid effect there, but I'm not entirely sure what color depth settings it used. Under windows if I go back to 16bit the grid pattern effect disappears as well.
Similar Threads
  1. Screen color distorts when moving it. g74sx
    By WhiteVulpine in forum ROG Gaming Notebooks
    Last Post: 12-04-2011, 07:24 PM
  2. G74SX color issue
    By Jassper in forum ROG Gaming Notebooks
    Last Post: 11-12-2011, 04:57 PM
  3. G74SX-BBK7 Sceen Color Question
    By SippyCupXIII in forum ROG Gaming Notebooks
    Last Post: 10-26-2011, 04:39 AM
  4. RMA did more damage than good.
    By Roach in forum ROG Gaming Notebooks
    Last Post: 09-03-2011, 12:20 PM
  5. to say awesome hardWARE/SOFTWARE
    By robertHR in forum Other Series Motherboards
    Last Post: 07-22-2011, 02:18 PM
