What s the difference between ASUS AI Suite and ASUS AI Suite 2
dctokyo
The R3E uses the ASUS AI Suite , but does the ASUS AI Suite 2 work on this board?
Motherboard: ASUS Rampage Extreme/ running Win7x64 Ultimate//Processor:E8600 //Cooling:Corsair CWCH50-1//Memory:Patriot DDR3 PVS34G1600LLK 8GB//Video Card: XFX ATI HD 5870 //HDD/Intel X25-M G2 80 GB & WD 74 GB VelociRaptor//Sound Card & Nic Card: PCI-e X-Fi Titanium Fatal1ty/EVGA Killer Xeno Pro //Case:SilverStone FT02B-WRI/No.0846//Power Supply: Corsair HX 850 //Monitor:Samsung P2770H 27"
8 REPLIES 8
Retired
Not applicable
nope ai suite II will not work
FlanK3r
why not?:(
Who knows me, knows me ;)....AMD 3000+, AMD x2 4600+ EE, AMD X4 955 BE C2,2x AMD X4 965 BE C3, AMD X4 970 BE C3, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD x6 1100T BE, 2x AMD FX-8120, 2x AMD FX-8150, FX-6300, FX-8300, FX-8320E, FX-8320, FX-8350, FX-8370, FX-8370E, FX-9370, FX-9590, AMD A8-3850, AMD A8-3870K, A8-5600K, A10-5800K, A10-6800K, A10-7850K, A10-7870K, A 5150, Athlon x4 860K, Intel i7-5960X, i7-6700K, Intel i7-4770K, Intel i7-980x, Intel i7 2600k, Intel i7-3770K, i7-3930K.
Retired
Not applicable
the architecture of the software is a different design. if you install the software on any other asus motherboard, it will either not install, or not work properly. AI suite II will be the new standard going forward, unfortunately it is not backwards compatible.
FlanK3r
thx 🙂
So far AI Suite II has been validated for Rampage III Gene, Rampage III Formula, and Crosshair IV Extreme and as Brian said, it will be the standard moving forward.
It would be nice to add in backwards compatibility for R3E, but that's something that maybe we can implement later on.
Mason
check out the AI Suite II video and overview in the Crosshair IV Extreme sub-forum
http://www.asusrog.com/forums/showthread.php?836-AI-Suite-II-video-amp-overview&p=4300#post4300
V2-V3
Thank you for the update Mason!
Wellcome. I have R3E and would ask You a question. How can AISuite II be compatible with lesser boards like Rampage III Gene, Rampage III Formula ??? Those boards are from same period of time so it seems You can make it backwards compatible , just tell me why add backwards compatibility first to lesser boards not the superior and most expensive one ? It seems riddiculous to me .
MOBO: MVIE BIOS 1402 stock
CPU Core i7 4770K
RAM: 16GB Corsair Dom. Platinum CMD16GX3M4A1866C9 in XMP, SPEC: http://bit.ly/Z56xfm
SSD/HDD: OS-SAMS 840Pro 256GB, APPS - SAMS 830 512GB, DATA - Seagate ST1000DM003
GPU: 2x EVGA GTX 680 FTW+ in SLI config (UEFI BIOS)
AUDIO: Onboard
CPU Cooling: Corsair H110
PSU: Seasonic Platinum 1000W (SS-1000XP)
CASE: NZXT Phantom 630
DISPLAY: ASUS VG278Q (120Hz)
