Hello all, Here is a small update, Add a cover to the GPU to hide the fittings
Gone over the face panel again with with some fin detail and added some matting base paint to all the rust to make it pop a bit more. and scotched some parts of the face panel to dull it up a bit.
Started doing some work on the cover door for the ROG base panel/DVD drive and so on.
Also Getting the vents all painted and bent up. and adding texture too them as well.
Have not had a lot of time to get much more done. but it's all starting to take shape.:)
