Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    New ROGer Array
    Dec 2011
    3
    Just bought a G74SX-XC1 and need help
    Just purchased it off the web (haven't taken delivery yet), and now having found this site, I'm crapping my pants that I'm going to have horrific issues with the touch pad, with latency issues, etc. etc.
    Would you recommend I try to cancel my order or roll the dice that I get a relatively unaffected laptop?
    I'm not computer savvy and I don't want to be having to try to figure out how to install and uninstall various drivers, how to mess with the bios or other stuff that is above my head. I just want a laptop that works right out of the box.
    Advice please.
    ROG Guru: Black Belt Array
    Oct 2011
    31
    2,916
    This is tough, because I really do like this laptop when it's working smoothly. But in my honest opinion, it's not a plug'n'play kind of computer, and I personally would not recommend it to friends who are computer-challenged. I know a lot of people like this....I'm their "tech support," so I know where you're coming from. Not everybody wants to spend time "tuning" a computer, any more than I want to spend time "tuning" a car!
    You probably wouldn't have actual hardware issues, but you could well run into the kinds of software problems you've read about here. There are resolvable, but it takes a little time and effort.
    If your retailer has a good return policy, why not get it, try it out for a couple weeks or so, and see what you think? If it's sufficiently trouble-free, you might find all the worry's for naught and decide to keep it.
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Quote Originally Posted by M240b View Post
    Advice please.
    If adequate support is part of your expectations, I'd lower those expectations and plan on learning to disassemble notebooks to fix small issues. You should also learn how to troubleshoot windows and driver problems.
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    New ROGer Array
    Dec 2011
    3
    My retailer has a replacement only policy.
    Like I said, I'm not computer savvy... I can install software and use windows software remover tool to remove it. That's about it.
    I don't know how to hunt for drivers to remove them and update them, other than using the search function with the file name. I'd never find them other wise.
    I very much do want something that is plug and play... and with a replacement only return policy, I thought it best to just cancel my order.
    Thank you for the advice.
    It sounded like a sweet laptop, but I'm not looking for anything that is going to cause me to be on the phone with tech support for hours on end and that is going to drive me up the wall.
    Thanks again for your honest opinion.
    New ROGer Array
    Dec 2011
    3
    Quote Originally Posted by JRd1st View Post
    Never had to worry about any of that when I had a Macbook Pro.
    ROG Enthusiast Array Symb's Avatar
    Oct 2011
    12
    38
    I was just about to say that if you want plug and play, go mac...
    *** G74SX-TZ226V (European model) | Kingston HyperX SSD 120gb Sata-III
    "STOCK" BIOS 202 (If it's not broken, why fix it.) *** <- Sold
  7. #7
    ROG Enthusiast Array ricksaint's Avatar
    Oct 2011
    11
    66
    Advice please.
    In a forum like this one, you're likely to read about problems more than anything else, although the problem units are probably a minority. The fact is that most people who buy our laptops lately have been quite pleased with them OOTB. Here is a sample from a search for " G74sx" from Amazon.com: http://www.amazon.com/s/ref=nb_sb_ss...sx&sprefix=g74.
    As you can see, they get 4.5 to 5 stars for almost all models.
    I, for one, am in love with mine.
    Asus G74SX-DH73-3D, Intel® Core™ i7-2670QM, Windows® 7 Home Premium, 64-bit - 14gb of RAM,
    Clean install on 128gb Crucial M4 SSD + 750gb WD 7200 rpm HDD for storage,
    Blu-ray™ ROM/DVD±RW combo drive, 3 GB (dedicated) NVIDIA GeForce® GTX 560M graphics, driver v. 285.62, 3D Capable.
    BIOS ver 203
  8. #8
    ROG Guru: Orange Belt Array
    Nov 2011
    14
    337
    if you are savy enough to (in an emergency) throw windows 7 dvd and install it AND install the drivers provided on jrd1st signature, than there's nothing to worry about.
    i would recommend alienware but they in the past had sound problems (lag) that was only solved 9 months later..
    there is no pc 100% error free and yes, the sentellic touchpad of the g74 is crappy..
  9. #9
    ROG Member Array
    Dec 2011
    17
    If you want something, I don't know, reliable, go sager or msi gaming laptops. If ASUS would buy back my G53JW I would pay to FedEx overnight that paperweight. The damn thing has more downtime than my Pentium D desktop. Now that's just embarrassing isn't it.
  10. #10
    ROG Guru: Green Belt Array fostert's Avatar
    Oct 2011
    54
    706
    My g74 is the most "quirky" laptop I've ever owned (formerly a Toshiba Satellite, and a Dell D610); by quirky I mean alot of minor strange behaviours which give me the impression that the thing is not the most stable or well thought out design (e.g. turning off touchpad in BIOS kills the keyboard, the numlock misbehaves, the insane amount of uselessware that demands new users to clean the system and start over with an install, etc). Not for the OOTB user; for sure there are better ones for lower maintenance. Gotta say my Dell D610 has never ever had any quirks, and is going strong after 6 solid years of use and travel.
