Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    goranthe
    Guest
    Problem with windows 7 64-bit
    When I install windows 7 ultimate , laptop run windows and when windows goes to the part when user loging mast show on screen, windows put some blue background with no icons and other staf. Help please
    Brian@ASUS
    Guest
    how clean of a install did you do? is this an upgrade? and is this a legit copy of windows or bootleg? Back up all your data and try doing another clean install with a full reformat.
    goranthe
    Guest
    Quote Originally Posted by Brian@ASUS View Post
    I have olrady tried clean instal with format several times and get the same resault. Is that becouse the windows is bootleg?
    goranthe
    Guest
    I'm not upgrade windows, I'm instal the new one. I have windows home premium 64bit but I wont to instal windows ultimate 64 bit. Do you have some sugestion or advise?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600
    Memory (part number)16GB DDR4
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,353
    Could be a bad disc. Does it look scratched?
    ROG Guru: White Belt Array
    Sep 2010
    75
    Goranthe, the best way to go about that is, if you have access to legal Retail or OEM Windows 7 64bit Home Premium disks install from that to give yourself a good fresh clean load using the license attached to your PC, to go from Home Premium to Ultimate from there I would suggest going the Anytime upgrade route either directly from Microsoft or a reseller of any sort.
    I used this to legally go from Home Premium to Ultimate
    http://www.newegg.com/Product/Produc...-772-_-Product
  7. #7
    goranthe
    Guest
    Quote Originally Posted by Pyro411 View Post
    Thanks a lot!!!
  8. #8
    Sep 2010
    75
    You're welcome. oh & the upgrade from Home Premium to Ultimate doesn't take to awfully long, I'd say from start to finish from Premium to Ultimate roughly 30-60 minutes in total after all is said and done.
  9. #9
    Brian@ASUS
    Guest
    yea some bootlegs depending on where its sourced from could have been corrupted. try to get at least an oem disk and using your serial key
  10. #10
    Sep 2010
    75
    *cough* I never posted this *cough*
    http://forum.notebookreview.com/wind...ml#post5437866
    The above URL is how to download the ISO from DigitalRiver "Microsoft's primary digital distributor" and how to edit the ISO file so it's universal.
Similar Threads
  1. My ROG Rig with Windows 7 ROG 64 Bit Edition
    By neuropass in forum Other Series Motherboards
    Last Post: 04-04-2012, 01:48 PM
  2. G71GX-RX05 Problem
    By Pmadison in forum GX/GM/GU Series Gaming Notebooks
    Last Post: 03-30-2011, 03:20 AM
  3. AC Power Supply Problem
    By thumper64 in forum G Series Gaming Notebooks
    Last Post: 12-30-2010, 03:28 AM
  4. Hardware problem I guess
    By freezeex in forum G Series Gaming Notebooks
    Last Post: 10-24-2010, 04:57 AM
  5. Problem with overclocking programs with R3E
    By AnthonyLackey in forum Overclocking & Tweaking
    Last Post: 08-05-2010, 04:55 PM
