G750JH Thermal Throttling problems and CPU stuck at 0.8 GHz
Njakka
Hi Guys.
I just had my 750 JH back from RMA and they exchanged most of the parts and im now unable to get more then 0.8 GHz from my Intel Core i7-4700 HQ processor. Thermal Throttling in also stuck at 100 % even on AC, although CPU temperature is between 40-46 C on high performance Power plan.
Any ideas how to improve the CPUs performance?
Thanks for all your help guys.
// Njakka
6 REPLIES 6
redduc900
Check out this thread if you haven't already...
Processor stuck at .77Ghz when unplugged [solved w/new bios]
http://rog.asus.com/forum/showthread.php?35062-Processor-stuck-at-77Ghz-when-unplugged-solved-w-new-...
Laptop: Asus G750JZ
OS: Win10
Money_Line702
RMA Replaced my motherboard, they are sending it back today. After what your saying Im getting nervous.
Darnassus
Status Under Review
If your board was replaced, just flash the BIOS to 208.
Njakka
I thought about that, but according to the asus support page, The latest bios is alredy installed. is 208 compatible with my Mboard? I sent the computer back to RMA, hopefully they can solve the problem.
Btw how do i Flash to 208, is there a guide or something on how to Flash?
Thanks.
redduc900
How to update the BIOS version in Windows system?
https://www.asus.com/support/FAQ/1008276/
Laptop: Asus G750JZ
OS: Win10
Darnassus
Status Under Review
Thanks, Redduc900 ;d
