Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array
    Apr 2013
    149
    G75VX Max HDD possible?
    What is the max. HDD I can put in my laptop?
    I have a 512 SSD and a 1Tb HDD.
    I want to replace the 1 Tb for a 2 Tb. Can I just go ahead with that?
    Thanks
    I Saw a WD Green WD20NPVX - Hard drive - 2 TB - internal - 2.5" - SATA-600 - buffer: 8 MB for $167
    TOSHIBA MQ01ABB200 2TB 5400 RPM SATA 3.0Gb/s 2.5" Hard Drive for $116
    SAMSUNG Spinpoint M9T ST2000LM003 2TB 5400 RPM 32MB Cache SATA 6.0Gb/s 2.5" Internal Notebook Hard Drive $109
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,129
    Sure if you can find a 2.5 " x 9.5mm form factor you can. You also can take out your DVD drive and get a caddy off ebay and put a hard driver there too I think it still has to be not thicker than 9.5mm thick. I haven't really looked at what is available in 2 TB drives but last I did they are 13MM I think.
    I just checked out the M9T ST2000LM003 and it says its 9.5mm with that slow 5400 a driver I think I would go for the DVD drive replacement.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
