I have a Noctua
NF-A14 for my rear exhaust and two Noctua NF-F12 on my Corsair H105 liquid cooler. The main reason I buy Noctua or Cougar is to run them at max speed. Anything over 26db annoys me, I can hear it and most other fans are in the 30's and in that case I can see using the attenuator or reducing the speed via the fan controller but I don't hear these guys at all. They have such good airflow and very low noise. No reason to reduce the speed. That's why you pay the extra money for them. I have the fan controller section that controls them off, and just set em at full speed.
Only advice I can offer concerning Noctura is to make sure it's the model you want. Bought a couple of NF-S12A, 107 cfm, 17db. I was happy until I realized I need a high static pressure to push air through the radiator. The NF-S12A have only 1.1 mm H2O (static pressure). Had to buy another set, the NF-F12. Lower airflow, 93 cfm, higher noise, 22db but 2.8 mm H2O. much better for a radiator. NF-S12A make a good case fan but not for cpu or radiator.
Desktop:> Intel i7-6850K/ASUS Rampage 5E/64GB Corsair 3000Mhz DDR4/ASUS PB287Q 28" 4k UHD 60Hz Display
Dual EVGA GTX 1080 Ti FTW3's in SLI/500GB Samsung Evo 960 M.2 SSD/8TB Seagate Barracuda Pro HDD/Win 10 Pro x64
Laptop:> ASUS RoG STRIX GL502VS/Intel i7-7700HQ/32GB 2400MHz DDR4/GTX 1070 8GB/15.6" 120Hz FHD G-SYNC Display
128GB SATA III M.2 SSD/2TB Seagate FireCuda SSHD HD/Win 10 Pro x64
