Results 1 to 10 of 23
Thread: Bootup Problem
07-05-2015 05:45 PM #1
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 13
Bootup Problem
Hi everyone,
I have been experiencing some issues of late. My case is a HAF X. The top IO panel was broken so I was replacing the. Before the replacement my computer was booting up fine and everything was normal.
After I replaced the IO panel my computer is refusing to boot now. The Q-Code doesn't go past 9c. I checked the manual and that says it's stuck on the USB detect phase.
I also checked the back of the motherboard. No USB hubs are working except the LAN1_USB3_E910. Every hub above that still has voltage but is refusing to charge my phone. The LAN hub also has voltage and does charge my phone when I plug it in.
I'm running out of ideas on how to fix this...
Does anyone have an idea and can someone please help me further?
I will post more information if it's needed to help the problem...
Have a fine day,
Neo
07-05-2015 06:08 PM #2
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
Have you tried disconnecting all your USB devices to see if your system would post correctly?
07-05-2015 06:39 PM #3
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 13
Yes indeed, I have removed every single USB device from the hubs. I had even disconnected the IO panel completely again from the motherboard. The system still hangs on the 9c Q-Code...
07-05-2015 06:41 PM #4
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
Try clearing your CMOS. If that doesn't help, switch to BIOS 2.
07-05-2015 06:49 PM #5
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 13
Yes I also tried that, clearing the cmos doesn't change anything, even on bios2 it still gets stuck on the USB detecting phase...
I even tried booting it into safe bios mode and it still wouldn't change a thing, it somehow doesn't get past the 9c Q-Code.
07-05-2015 09:35 PM #6
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 13
Hi again, i have an update.
I took the whole motherboard out of the case, the only things attached to it are the memory cards, cpu and the powercables.
I plugged both the 8pin and 4pin cables along with the EZ-plug cable.
But now the system just turns itself off after 2 or 3 seconds of powering on. Like it's short-circuiting.
But i checked all the cables, they are firmly attached and all the led lightd on the board are also lit up, the rog logo has a fading effect too...
Can anyone help me please?
07-05-2015 10:02 PM #7
TheQuickOne PC Specs Motherboard ASUS RAMPAGE V EXTREME Processor Intel Core i7-5820K Haswell-E 6-Core @4.5GHz Memory (part number) F4-2400C15Q-16GRK Graphics Card #1 GTX 980 STRIX Graphics Card #2 GTX 980 STRIX Monitor QNIX QX320QHD Super Ultra 32" 2560x1440 Storage #1 2x SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512G Storage #2 2x Seagate Barracuda STBD2000101 2TB CPU Cooler Akust WC02-0004-AKS Larkooler SkyWater 330 Case NZXT H440-White Power Supply FSP Group AURUM PT Series 1200W Keyboard RGB CORSAIR K70 Mouse LOGITECH G600 Headset/Speakers M-AUDIO AV40, Dayton Audio SUB-1200, Klipsch Status OS Window 7 64 Accessory #1 snowglobe blue
- Join Date
- Jul 2015
- Reputation
- 10
- Posts
- 11
Just a guess, but if you had a short, you would probably smell smoke and here a pop noise. It sounds more like there is a break in the circuit if it is something electrical.
07-05-2015 10:22 PM #8
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 13
Could be, but i checked over twenty times at least...
I can't seem to find anything, could you point me in a direction please?
07-05-2015 10:30 PM #9
- Join Date
- Jul 2015
- Reputation
- 10
- Posts
- 11
Unfortunately, that's where my knowledge ends. Sorry.
07-05-2015 10:32 PM #10
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 13
Ah alright then, no problem, the effort is what counts
Can someone else shed some light on this problem please?
