Results 1 to 2 of 2
    New ROGer Array
    Jul 2015
    1
    Asus G53SX-A1 CPU Overheating after Power Jack Repair
    Hello and thanks in advance for any help.
    Has the tittle says, my Assus G53SX-A1 is having some CPU Overheating issues that started after the power jack got repaired (its center pin broke) with another thats exactly the same.
    Before that, the CPU Fan (the left one) almost never went full blast while just using it for downloading or web browsing, but now, its on full speed almost 85% of the time, sometimes even if left idle for a while, coming to the point where the CPU throttles ALL the cores. My CPU Temps while web browsing (Opera, just Facebook and two other tabs a most) are : 77°C - 90°C
    My CPU Temps while Playing Dota 2 (1080p, all on high and every option activated minus v-sync) : 95°C - 101°C
    Here are some images i took with RTSS and HWiNFO64 options:
    http://postimg.org/gallery/2ab149xxe/
    Before the problem, i could run Dota 2 on the same settings at 40-45 fps, but now it doesnt even reach 30, with dips into 10s after a teamfight. The same happens in League of Legends, Fallout 3 dropped about 10 fps, cant watch youtube 1080p 60 fps videos (they lag).
    Note aside, im using the CoolerMaster Notepal U3 with 2 fans on the CPU side and 1 on the GPU (which never goes over 45°C while idle and 65°C while gaming).
    The vents, fans and overall interiores have already been cleaned, i havent repasted because i dont have thermal paste and the present one is still spongy and not dry (more like thermal pads i think).
    Im going to format it to see if that helps, but i hope someone can help me.
    If more info is needed i will be happy to provide it.
    ROG Guru: Orange Belt Array C4RN1 PC Specs
    C4RN1 PC Specs
    Laptop (Model)G51VX, G71G, G73, G74SX, G53SX, G53JW, G46VW, X501A, X401A
    MotherboardASUS M5A88-V EVO
    ProcessorAMD FX-4350 Vishera Quad 4.2GHz
    Memory (part number)16GB 4x4gb Mushkin Black Line
    Graphics Card #1HD Radeon 5970
    Graphics Card #2HD Radeon 5970
    Graphics Card #3HD Radeon 5970
    MonitorSamsung SyncMaster SA450 x2 (Provided by HP)
    Storage #1Corsair Force GT 120GB SSD
    Storage #2Western Digital 1.5 TB HDD
    CaseAntec 900
    Power SupplyKingwin Lazer 1000W
    Keyboard HP OEM
    Mouse Logitech Anywhere MX
    Headset ROG Orion
    OS Windows 7, Windows 8.1
    Network RouterLinksys E-1000 (DDWRT)
    C4RN1's Avatar
    Jul 2012
    16
    264
    Stop using the computer before you break it.
    First reapply the thermal compound, if that doesn't solve the issue then replace the cpu heatsink.
    More than likely you bent the cpu heatsink just right and damaged it so it no longer transfers heat as it's designed. I've only seen this happen a couple times, but the symptoms are exactly the same as you're experiencing. If you have a thermometer measure the temps in the middle of the bracket over the cpu then measure the temp going down the heatpipe. You'll find where the heatsink went bad (usually there's a fine crack or sharp bend).
    Here's a link to a used heatsink on ebay - http://www.ebay.com/itm/Asus-G53SX-C...item1e93230698
    The community uses IC Diamond thermal compound because it's thick and it's one of the best performing thermal compounds.
    Do not spread ICD, read on how to apply here. http://www.innovationcooling.com/application.html
    If you have any other questions let me know.
Tags for this Thread
