Results 1 to 9 of 9
    ROG Guru: White Belt Array
    Jan 2015
    75
    g750jx - new power supply?
    hi,
    i have a g750jx, there are two slices in the cord attached to the power supply. ive taped it up.
    Do you think ASUS would send me a new power supply free of charge? :-)
    thanks
    ROG Guru: Green Belt Array Maxter's Avatar
    Aug 2013
    13
    598
    If you bought through BestBuy, their insurance allows you to have one free power supply and a free battery (assuming you're in the US). ASUS won't send you a power supply. You can buy one online, however. They run at about $120.
    Jan 2015
    75
    no, i didnt buy it at best buy :-( and im in Canada.
    Aug 2013
    13
    598
    then, get ready to shell out some $$$...
    http://www.uspartsdirect.com/180w-or...cHbRoCGM_w_wcB
    here's some extra info within the threads https://rog.asus.com/forum/showthrea...-charging-quot
    Jan 2015
    75
    this seems like a better deal,
    http://www.amazon.com/iTEKIRO-G750JW.../dp/B00EYLIPH6
    50 bucks.
    still alot though.
    *sighs*
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    Do not buy a fake/copy charger for an expensive laptop.
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
  7. #7
    Aug 2013
    13
    598
    Follow Darnassus recommendations.
    An alternative charger is the one bestbuy sent to me (assuming bestbuy doesn't want to break my laptop or they'll have to fix it or give me a new one anyways):
    Delta Electronics, INC. Model: ADP-180EB D
    Output: 19V --- 9.5A (which is 180 Watts - like the original ASUS one)
    I've been using it with no issues for over 6 months. Battery is still pretty good.
  8. #8
    Jan 2015
    75
    i dont understand,
    wouldnt any charger that is not made by asus be a fake/copy? so then the delta charger you mentioned is a fake/copy.
  9. #9
    Aug 2013
    13
    598
    The delta charger it's definitely a copy. But if bestbuy trusts it, I trust it. As I mentioned, my laptop is under warranty. A bad charger = burned MoBo = new laptop for me = loss to them. I doubt they would have sent me a cheap knockoff... (they payed $80 for the charger they sent me). So probably there are delta charger fakes too o.O
