07-09-2015 04:25 PM - last edited on 03-06-2024 02:32 AM by ROGBot
07-09-2015 04:43 PM
07-09-2015 06:16 PM
Chino wrote:
1. I doubt anyone would be able to answer this question. The general rule is to keep it as low as possible. As a sidenote 4.4GHz at 1.2V isn't bad. If you invested in some better cooling, you could get those temperatures down to overclocker your CPU further.
2. I mostly use HWMonitor as that works for me.
07-10-2015 12:43 AM
07-11-2015 06:06 AM
GoNz0- wrote:
I can answer that, always take the highest temp, even if you are not sure. BIOS and AI Suite take motherboard temps, CPU Package and core temps are read from the CPU so you want to use those.
With good cooling you can push it into the 80's none stop but ensure you have good case ventilation and a water cooled solutions preferred for constant stress from an application like lightroom to stop you dumping the heat into the case.
3 hours gives you a very good upper limit and for the tropics I wouldn't worry about those temps.
