Results 1 to 4 of 4
    ROG Enthusiast Array
    Jul 2015
    27
    G74SX Secondary Hard Drive Ribbon
    A couple of days ago, I took apart my G74 in order to inspect a failing motherboard before I got a new one. It seemed to go smoothly, but I should've realized something:
    In life something will always go wrong on your first time doing something.
    Anyways, it appears as if I damaged the ribbon cable for the second hard drive, bending pretty much all the metal connectors at the end of the cable from inproper insertion to the MOBO, though it doesn't seem that any were torn.
    I'm having a hard time just finding a new hard drive kit to buy that includes the cable and doesn't cost as much more than the hard drive itself, let alone just the cable.
    Does anyone know of any that I could purchase, or if I could possibly just straighten out the connectors as much as I can and allow it to work that way?
    Pics coming later
    Jul 2015
    27
    Thread bump
    Whups, forgot to upload the images:
    Sorry for the potato quality of the actual ribbon (no manual focus), but it gives an idea of the damage. Does anyone think I could risk straightening the contacts and using it?
    EDIT: Seems like the forum didn't like the size of the pic and regurgitated it. Will upload smaller one.
    ROG Guru: Orange Belt Array C4RN1 PC Specs
    C4RN1 PC Specs
    Laptop (Model)G51VX, G71G, G73, G74SX, G53SX, G53JW, G46VW, X501A, X401A
    MotherboardASUS M5A88-V EVO
    ProcessorAMD FX-4350 Vishera Quad 4.2GHz
    Memory (part number)16GB 4x4gb Mushkin Black Line
    Graphics Card #1HD Radeon 5970
    Graphics Card #2HD Radeon 5970
    Graphics Card #3HD Radeon 5970
    MonitorSamsung SyncMaster SA450 x2 (Provided by HP)
    Storage #1Corsair Force GT 120GB SSD
    Storage #2Western Digital 1.5 TB HDD
    CaseAntec 900
    Power SupplyKingwin Lazer 1000W
    Keyboard HP OEM
    Mouse Logitech Anywhere MX
    Headset ROG Orion
    OS Windows 7, Windows 8.1
    Network RouterLinksys E-1000 (DDWRT)
    C4RN1's Avatar
    Jul 2012
    16
    262
    Your best bet is to get the fcc cable from Asus parts in Sweden.
    http://www.asusparts.eu/en/Asus-14G124080160
    ROG Member Array
    Aug 2011
    14
    here's another from asus usa.
    http://us.estore.asus.com/products/14g124080160
