Why rush into updating both copies of the dual-BIOS? Always keep the best/last problem-free version in one partition as something to fall back onto, only need to update the other. Just leapfrog between the two whenever a new BIOS comes out. Weird problems may not always manifest until after the machine appears to work perfectly for a long time, being able to quickly boot up the older BIOS can rule out (or confirm) BIOS-related issues. I have never personally irrecoverably bricked a motherboard from bad firmware flashing, I have never personally met anyone else who has either - it's not an impossible event, but it is a highly improbable one.
I wouldn't normally advise everyone rushing into routinely upgrading the firmware just because new firmware happens to be available. Not unless it specifically corrects some issue of importance or substantially improves compatibility or performance or capabilities. But as an R5E owner I always get sucked in, gotta try the latest-greatest and see if there's any truth to the claims that it's more better faster awesomer than ever before, so how could I discourage others from doing the same?
I still believe that Asus is horribly irresponsible in providing end users with absolutely zero BIOS documentation or version notes. Not even the briefest and vaguest of summaries. At best, regular visitors to these forums might see "unofficial" hints about what's eventually coming down the pipeline. We must blindly trust that newer must be better, that what Asus decides is best-for-everybody-else is also always best-for-us, and we must actually install/run the firmware updates to learn what's been changed. A little documentation would go a long way, I think, in informing people whether or not they should expect a particular BIOS version to resolve (or cause) issues of concern. Damned good thing our ROG mobos have multiple BIOS chips, if they didn't then I'd never dare to update (and maybe break) anything which already appears to be working well. That's a pretty weak position for a leading hardware manufacturer. It's affected my purchasing choices before, if left unchanged it will again.
[/Korth]
