Results 1 to 3 of 3
    New ROGer Array
    May 2014
    2
    G750JH Laptop not charging
    HI all,
    I have a G750JH and yesterday it stopped charging for some reason, I was playing a game and it started to lag and when I checked the battery Icon it showed not charging, I removed the battery and tried to start the laptop that way and it started but after a minute or so the laptop stopped.
    I tried to check if maybe a battery calibration would fix the problem but it didn't, The strange part is that once the battery was completely drained it charged back(over night, this morning it was at 100%) but once I start the laptop it will not charge again.
    Anyone have any ideas?
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    Your charger must be stuffed. Give the cord a 'massage' from the brick to the plug and wiggle it around while it's plugged in. Watch the charging icon see if it turns on.
    If it changes between on and off, you need a new charger.
    Buy a legit charger too, not a copy / knock off. Pay the $120 or what ever.. it's a $2,000 laptop.
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    New ROGer Array
    May 2014
    2
    I tried that first, It did not do anything. I will just send it to the asus service here and let them figure things out. My best guess from what I read here on the forum is that it was a manufacturing problem with the power distribution chip(I had some random 1 seconds power drops from the beginning, I assumed it was normal(I'm not that smart sometimes :| )). Thanks for the reply anyway .
