Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Nov 2014
    79
    g750js power4gear hybrid aned normal temperatures questions
    I recently installed that program but i dont see any difference in fps and temperatures while i am playing games. Maybe i miss something. Can you guys explain me what does this program exactly do and do i really need it?
    I want to keep my computer (g750js) cool as possible while playing games, this is my highest priority.
    I am getting gpu/cpu temperatures arround 70-80oC while playing heavy games at high setting, are these normal?
    Also when do i have to re-paste my computer?
    ROG Guru: Green Belt Array Maxter's Avatar
    Aug 2013
    13
    598
    There is somewhere in the forum a thread with this question. I performed a study on temps (my laptop is the JW) and found that the effects are on battery only (with an older version of P4G). Truly, I don't think it matters. I would allow Windows to control everything. The new versions of P4G are not that good...
    ROG Guru: Yellow Belt Array code9523 PC Specs
    code9523 PC Specs
    Laptop (Model)ASUS G750JH 3D Custom!
    MotherboardG750JW Motherboard REV 2.0 PCB Made in China)))
    ProcessorIntel Core i7 4700HQ
    Memory (part number)4x8GB DDR3 1600MHz HMT41GS6AFR8A-PB
    Graphics Card #1NVidia GTX780M with G750JZ Copper Heatsink
    Sound CardRealtek Hig Definition Audio
    MonitorSamsung LTN173HT02 [17.3" 120Hz 3D LCD]
    Storage #1120GB (OS) 240GB (Games) Kingston HyperX Fury SSD's
    Storage #2750GB WD Black (7200 RPM)
    CPU CoolerStock G750JH cooler
    CaseStock G750JH
    Power Supply230W (ADP-230EB)
    Keyboard Mod G750JZ
    Mouse ASUS ROG Gladius
    Mouse Pad CYBORG G.L.I.D.E.7
    Headset/Speakers SVEN =)
    OS Windows 10 Home x64
    Network RouterZTE
    code9523's Avatar
    Feb 2013
    11
    215
    I'm also on windows power settings and i'm on high performance mode always. I didn't got any difference in fps and temps when I had P4Gear installed on my G750JH and other lappys. But I may be wrong so please let me know.
    Asus G74SX> Asus G55VW 3D> Asus G75VW 3D> Asus G750JW> Asus G750JX> Asus G750JH
