Enhanced Overclock not working
hacker1122
Hi! I have the Asus GTX 970 STRIX and recently i have upgraded to Gpu Tweak ver. 2. In the settings, to see if there's some new features, i've see the "Enhance Overclocking Range" to go over the limit of the software. Nothing New. The only problem is that if i try to enable it, nothings change, the limit is the same, and i cant go beyond that. I have Windows 10 RTM x64. What is the problem? Is a bug? Or something like that?
Thanks,
Luca.
4 REPLIES 4
InfernoStorm
Some options are locked or unavailable because of the BIOS version on your card. Even though you can click on it doesn't mean that it should work, technically when you enable something and it doesn't work, it means the same thing as the option being greyed out. Of course it would been nice of to have the software to just grey out the option so it won't leave us wondering why it isn't working..
hacker1122
The thing is ... With the first version of GPU Tweak is working fine 😕 (I Mean the latest version of GPU Tweak I)
InfernoStorm
Must be a bug with GPU Tweak II then.. 😕
In fact in the new verson 1.0.6.9 is now fixed 😉
