BIOS 2702
I noticed that my #1 Chassis fan was switched off when I thought it should have been spinning. This made me check the fan settings in the bios.
It seems there is an inconsistency in the detailed view of the fan control and the 'Qfan Control' graphical section.
All temperatures were set to 45, but the graphical section showed them being 45,50 and 55.
The Fan was still off when the temperature was above 45.
The graphs become useless when it is easier to check and set all variables in the detailed view, although more fun to play with... It seems the temperatures are read from the graph and the detailed view has been turned redundant. Please fix this.
I can live with not having the 'source' on the graphical display... but if you could add that in while you're fixing? That would be great! 😄
PS. Thanks for sorting the fan control a little with the last BIOS release... The fan control seems to work a lot better now.
