Results 1 to 5 of 5
    New ROGer Array
    Jul 2015
    3
    Please help me with some G751JT graphics, pixel, charging, and sound issues
    I bought a new G751JT yesterday but i have some problems:
    - Where is my intel HD graphic, i have only gtx970m
    - I found a stuck pixel on screen. May i change a new one
    - Are there any software to stop charging if the battery over 50% or 80%
    - Speaker under being shy when volume over 50%
    Please help me,
    ROG Guru: Yellow Belt Array antoine52200 PC Specs
    Laptop (Model)G751JT
    MotherboardASUS
    Processori7-4720HQ OC at 3.8Ghz
    Memory (part number)16Go 1600Mhz OC
    Graphics Card #1NVIDIA GTX 970M OC
    OS Win10 64bits
    antoine52200's Avatar
    Jul 2015
    241
    At this point i would just send it back and get a new one! best thing to do! there isn't optimus on your laptop so you can't switch between dedicated and intregrated graphics (which is a good thing for me) the battery will stop charging when at 97/98/99/100% charged. Have you check sound drivers on asus website ? maybe a new one is available.. Have you try the audio wizard to change volume, bass..etc
    New ROGer Array
    Jul 2015
    3
    Thank you but can i change a new one if i have only one stuck pixel ?
    MotherboardASUS
    OS Win10 64bits
    Jul 2015
    241
    yes you should be able first call the shop you bought it from, and if they say no, call asus support!
    New ROGer Array
    Jul 2015
    3
    Thank u so much
