Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    New ROGer Array
    Aug 2015
    1
    Problem on my Tytan G30AB after Windows 10
    Hello everyone,
    First time posting on the foruns, i need some really big help. After i updated my asus to W10 my overclock button no longer works, i'm not able to put the i7 on 4.1ghz. If anyone knows how can i solve this please let me know.
    Thanks a lot in advance.
    ROG Enthusiast Array geniusdevil PC Specs
    Laptop (Model)ASUS G30AB
    MotherboardASUSTeK G30AB Z87 Chipset
    ProcessorIntel(R) Core(TM) i7-4770K CPU @ 3.50GHz, 4 Core(s)
    Memory (part number)16GB DIMM DDR3 1600 MHz clocked @ 1605 MHz
    Graphics Card #1ASUS STRIX 960 OCDC2 2GB
    MonitorHP w2558C Vivid Color Widescreen LCD Monitor 25.5"
    Storage #1Samsung 850 EVO 500 GB on AHCI
    Storage #2Toshiba SATA HDD 3TB on AHCI
    CPU CoolerCorsair H60
    CaseASUS G30AB
    Power Supply700W
    Keyboard SteelSeries 6G V2
    Mouse Logitech G500s Gaming Mouse
    Headset SteelSeries Siberia V2 Full-Size Gaming Headset
    Mouse Pad SteelSeries
    Headset/Speakers SteelSeries
    OS Windows 10 Pro
    Network RouterAirport Extreme
    Apr 2015
    11
    31
    Hey,
    I was about to upgrade to Windows 10, but now that you've mentioned this problem -- I believe i should wait. Let me know if you find the solution. I will wait until the AI Suite II works on Windows 10.
    BTW, did you try uninstalling and then installing AI Suit II? Tried the AI Suite Driver directly from the ASUS website? Let me know.
    Cheers,
    A.
    P.S. When i ran the PC Check with Windows 10, it doesn't show any problem. Take a look:
    CaseASUS G30AB
    Power Supply700W
    OS Windows 10 Pro
    Apr 2015
    11
    31
    Hello again.
    So, I couldn't wait to install Windows 10 on my ASUS Tytan G30AB, and I am pleased to announce that the AI Suite II works just fine with Windows 10 Pro. Here's what I did:
    Upgraded to Windows 10 Pro, and made sure that it's activated.
    Created a bootable USB and performed a clean Install with the disk formatting.
    Installed the Windows 10. Installed the Chipset driver that came with Windows 8.1. Restart the system.
    Installed AI Suite II (from ASUS support website). But then, the button was working -- it just didn't pop up the notification. I opened the AI Suite II and clicked System Level UP, which showed the bar increased towards the 4.1G. The lighting wasn't changing to RED either. So I installed the updated driver of "System Level UP" (again found on ASUS support website). Restarted the system and voila! Everything seems to be working just fine.
    Hope this helps!
    Regards,
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    74
    2,416
    I did the same when I installed W10 , I installed the updated driver of "System Level Up" from the G30AB driver page. , I installed the "System Level Up" driver Version 2.02.01 released on 2014/02/11 now when I use the level up button on the G30AB , I get No pop up showing the level up speed has changed and the lights on tower changes colour as it did in W8 have to open AI Suite II to change speeds , my other bug on my G30AB with W10 is the Blue Ray Drive no longer auto plays with a music CD or a Movie Disk , I have to tell the DVD Music software or BD software to play the disks manually.
    AI Charger no longer is available with my W10 install , Tried reinstalling the AI Suite II software from asus ,
    NO AI Charger when reinstall of AI Suite software With W10 , Some features of AI Suite is incompatible with W10 is my guess
    New ROGer Array
    Aug 2019
    3
    Feature Updates not working on Asus G30AB ?
    Quote Originally Posted by geniusdevil View Post
    Hello again.
    Hope this helps!
    Regards,
    Hi guys,
    I also have a G30AB. It works perfectly fine under windows pro 10 but when it comes to updates it's another story. Each time I try to install a feature update like 1903... the computer is stuck at 30% or 70% and after a hard reset it rollback the update. I had this already in the past and my only solution was to put the os drive in another computer (Acer Predator 7700) in order to update successfully the os.
    Do you also have that issue with updates ? Did you find a way to solve it ?
    Thanks a lot for your help,
    J
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    74
    2,416
    I Could Never Update My G30AB To Any Version Of W10 Except The First Release , All Updates Failed At 70% , So I Replace The Motherboard , Asus Service Centre Near Where I Live Said It Was A Bios Issue That The G30AB Would Not Update Or Install W10 , G30AB Is A Great Case , That's Why I Installed New MB did Not Cost Much , And Some Of The Orignal G30AB Software Still Works
  7. #7
    New ROGer Array
    Aug 2019
    3
    Windows 10 Compatible motherboard for G30AB
    Quote Originally Posted by toronto699 View Post
    Thanks a lot for your answer (I felt so alone with this problem). Could you tell me what MB you bought ?
    Is it compatible with the cooling system... and the overclocking button ?
    (My config : i7 4770 3.5 ghz / 32 Go ram / 500 Go ssd 860 evo / GTX 1070 / Oculus Rift S)
    Many thanks again...
  8. #8
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    74
    2,416
    The Mother Board Is about 4 years Old Now Better To Buy New Motherboard , The Cooling Should be Compatible because the boards have screw holes For Cooler of Processor , As For Over Clocking The 8.1 software worked but not sure now with new versions of W1O Microsoft Sent Me Blocking Tool , So I Will Never Update Or Upgrade The OS , PM Nate He Will Help You Select A New Board , List All Hadware With Nate , All Your Harddware Listed Seems Compatible With New MB But Maybe Not The Ram , Tell Nate The Cooling System You have , And All Hardware OK , There is A Post Somewhere Here In These Threads Were 2 others upgraded The MB But Its 3 , 4 years ago, So Newer MB Is Better
    https://rog.asus.com/forum/member.php?107341-Nate152
    Over Clocking Software Should Work In New MB And Older Over Clockable Processor i7 4770K Your Processor
    https://downloadcenter.intel.com/download/24075
  9. #9
    New ROGer Array
    Aug 2019
    3
    Thank you very much for all this helpful information.
    J
  10. #10
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    74
    2,416
    Tytan G30AB Cooler Is Self Contained ICE I Believe , No Maintenance Needed ,
