Results 1 to 5 of 5
    ROG Member Array
    Aug 2015
    14
    Qfan tuning problems
    I already post this in the Bios 2801 thread but forgive this double post cause things are most irritating. I got a Maximus VII Ranger with 2 chasis fans in DC Mode and one CPU fan in PWM mode...qfan totally messes everything up, making the cpu fan running at 100% speed at all times. Manual tuning is really messed up, sometimes it works for chasis fans but not for the cpu one , sometimes the opposite...It locks temperatures and speed in random values that cannot be changed, sometimes at 100% some other times at 60% etc. I've tried restoring defaults and reflashing the bios without success... Qfan tuning started messing things up even from 2 previous versions but I always found a way to fix it. This time things are hopeless no previous solutions seems to work...
    ROG Guru: White Belt Array Norcus PC Specs
    Norcus PC Specs
    MotherboardMaximus VII Gene (Z97)
    ProcessorCore-i7 4790K
    Memory (part number)16GB (KHX1866C10D3/8G)
    Graphics Card #1GTX780 OC DCII
    MonitorRog Swift
    Storage #1Samsung 840 EVO 1TB
    CPU CoolerEK Supremacy
    CasePhanteks Evolv
    Power SupplySeagate 860W Platinum
    Keyboard Orion Spark
    Mouse Proteus Core
    OS Windows 7
    Sep 2014
    111
    Run QFan a couple of more times. If that does not help, clear CMOS and go back to 2702.
    ROG Member Array
    Aug 2015
    14
    Thx for the answer. Will try running it more times...shall I put everything in default before doing so? The funny thing is that 2702 also had similar issues lol...
    As for clear CMOS function, I turn off the PC (do I have to unplug it also?) and press the clear CMOS button on the MB right? Anything else I have to do?
    ROG Member Array
    Aug 2015
    14
    Well, I ran the Qfan 2-3 times more and in the end it actually got the correct values. Too bad the fan doesn't obey these values, meaning the fan is set to work at 30% below 50 degrees and it runs at 60%... hopeless
    Norcus PC Specs
    MonitorRog Swift
    CasePhanteks Evolv
    Mouse Proteus Core
    OS Windows 7
    Sep 2014
    111
    If the DC fan is set to 30% it means the motherboard supplies it with 30% power. It does not translate to 30% of max rpm. PWM fans should be more predicable in that way, but each fan is different. Same brand and model usually stay around the same rpms at the same power.
    As for resetting CMOS there is a button on the rear IO panel. Read the manual.
