08-06-2015 12:50 AM - last edited on 03-06-2024 09:28 PM by ROGBot
08-06-2015 12:56 AM
05-22-2017 01:43 AM
clockworksatan wrote:
I found this by doing a google search; might be worth a try:
1. Go into the control panel and select Device Manager .
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
08-06-2015 01:12 AM
08-06-2015 01:12 AM
08-06-2015 01:30 AM
InfernoStorm wrote:
So the issue is the battery doesn't charge to full and it will say plugged in and not charging?
Since you already looked through internet for solutions so I'm guessing you already tried the discharging trick?
It's most likely a memory issue with the battery, likely need to get it replaced.
08-06-2015 01:53 AM
petcuaanh wrote:
Yes 😞 it stays at 98% all the time and say not charging , please show me the discharging trick
I don't want anything to be replaced too soon , not when I just enjoy a little bit of it 😞
08-06-2015 02:42 AM
08-06-2015 03:15 AM
JBM wrote:
I believe this has been covered before on the forum a few times, that if its power is plugged in it is quite normal for the battery to hover around 95-100% and
state plugged in not charging.
