Results 1 to 2 of 2
    New ROGer Array
    Apr 2015
    4
    [HELP] Safe Overclock for Asus ROG G751JT DH72?
    I'm trying to overclock my laptop with GPU Tweak but I'm not sure what is safe. I changed the refresh rate from 60 to 75 but not sure what is safe for the rest? Rest is at default atm.
    ROG Guru: Yellow Belt Array antoine52200 PC Specs
    Laptop (Model)G751JT
    MotherboardASUS
    Processori7-4720HQ OC at 3.8Ghz
    Memory (part number)16Go 1600Mhz OC
    Graphics Card #1NVIDIA GTX 970M OC
    OS Win10 64bits
    antoine52200's Avatar
    Jul 2015
    241
    75Hz is safe no worries, i've set mine to 90hz (inside Nvidia control panel not gpu tweak) but do some research, look for tutorials before playing with it.
    But GPU clock you can add 135 (it's the max)
    Memory clock you can safely add 300 or 350. If you want more just add 10 more do a benchmark and so on..)
