Offical Audio Drivers for W10?
Jeracan
Greetings all!
Just finished upgrading to W10 and everythings to work fine. Even the Nvidia drivers went up and running smooth.
But went to the offical site but no Audio drivers were found for Windows 10?
Should I just keep the standard audio in W10 for noe and wait? or do we have them some other place?
Sorry if this has been asked 100 times before 😞
52 REPLIES 52
AQUASTEVAE
there is a thread. but you should use 7560 from realtek
CoolerMaster Maker 5T - ASUS CROSSHAIR VIII EXTREME - 65-inch UHD 4k SAMSUNG Q8FN - AMD Ryzen 9 5900X - NZXT Kraken X72 - 10 SIRIUS LOOP/NZXT RGB Case Fans W/ HUE+ - Gigabyte AORUS 1080 TI EXTREME - 64GB GSkill TRIDENTZ NEO 3600Mhz DDR4 - 3X XPG GAMMIX S70 2TB NVMe SSD'S- 2X CORSAIR FORCE MP600 NVMe SSD'S - WD BLUE 8TB HDD - Logitech wireless KRAFT advanced keyboard - Logitech M570 wireless trackball - Dual booting WIN 11
Ohh ok thanks for the reply! 🙂 Will try see if I can find it.
Jeracan
Still no luck finding these drivers for W10, anyone able to help?
After I upgraded to Win 10 I just opened device manager and right clicked Realtek in Audio devices and selected update device drivers and used the option automatically find latest drivers. It updated mine to 7571.
yeah, i also updated to 7571. so far so good.
PawPaw
The sticky imbalanced sound problems has all the drivers which work in win 7 8 and 10.....as to which he is best...that's a hard call and more down to user preference. ...my speakers rattle no matter what...and sometimes crackle....seems the 751 is weak in the speaker department which is why I use headphones most of the time..
Jeracan
Thanks for the info, also updated mine from device manager! 🙂
benjmyers1
7576 is out
benjmyers1 wrote:
7576 is out
Any idea where? I can't find it on the Asus site, Realtek site or Windows Updates.
