First Post, Any tips? Should i suffice for what i got?
smitty371
Decided to finally post after constant researching and tuning. Questions and comments are all welcome, also wondering if i should try at any more tweaks. Specs are as listed
Other Freq:
NB @ 2500
HT @ 3000
Voltages:
Vcore @ 1.488-1.5
VDDA @ 2.60
DRAM @ 1.675
GPU @ 1.294 (Max allowed through ASUS GPUTweak)
Temps: First set are Metro 2033 Last Light/Sniper Elite 3/Crysis 3/GTAV temps
Socket @ 20C(67F) - 42C(107F) [Max @ 61C with Prime95]
CPU @ 16C(63F) - 56C(132F) [Max @ 63C with Prime95]
MOBO @ 23C(73F) - 26C(78F) [Max @ 28C with Prime95]
GPU @ 28C(82F) - 56C(132F)
Pictures first one is rewire and current last is a day old but with it on of course... Thank you for your time
5100351004
8 REPLIES 8
smitty371
Update and Edit:
Other Freq:
NB @ 2408
HT @ 3130
GPU @ 1170/6000
Voltages:
Vcore @ 1.524-1.536
CPU/NB @ 1.275
VDDA @ 2.575
DRAM @ 1.65
NB @ 1.2
Socket @ 30C(86F) - 47C(116F) [Max @ 68C with Prime95]
CPU @ 12C(54F) - 53C(126F) [Max @ 59C with Prime95]
MOBO @ 29C(84F) - 31C(87F) [Max @ 32C with Prime95]
GPU @ 28C(82F) - 66C(151F)
MaxxMEM: 13.45 GB/s @ 63.2 Gain
51267
51268
51269
Arne_Saknussemm
Level 40
Thanks ya I was itching for more organized and more view and I couldn't take it anymore lol also eventually want to go to full water setup with those custom EK setups like what you got and more mild lights either red or white, also strive hard to find ROG or just red/black/white GPU casing or heatsink, love red too much but I'm still novice to any water cooling hence why i got simple ready to go even though i should've waited since my CM X6 elite was not much hotter
Arne Saknussemm wrote:
Nice upgrade...looks a lot neater in there 😄
^A lot! 🙂
I think you're asking for trouble at those voltages 😛
your MaxxMEM score seems a bit low.
in AIDA64 test i get 45GB/s, but i'm also running quad channel 😛
Watercooling FTW :cool:
"essentially one of the most hardcore overclocking motherboards ever made."
http://www.hardocp.com/article/2014/03/24/asus_rampage_iv_black_edition_motherboard_review/7
Ill be sure to check it out thanks chrsplmr
Which voltages are you referring to? M11C
ya I've felt like my memory has always been iffy for some reason but for some reason at stock 1600 maxxmem read at roughly 10GB/s
chrsplmr
Level 18
Smitty371 - Welcome to ROG.
Nice setup ... Well ROG'd !!!
I have a tip for ya to check out your ROG'V'nesses .. and have some Great Fun as well !
http://rog.asus.com/rog-pro/realbench-v2-leaderboard/?Laptop=all&CPU=amd&gpu=all&Core=all&view=2
Best of Luck. Please, Keep us Posted. .c.
smitty371
Update on Everything:
NB @ 2408
HT @ 2648
RAM @ 1926 w/ 9,10,9,27,36
Voltages:
Vcore @ 1.5-1.512
CPU/NB @ 1.23875
VDDA @ 2.53875
DRAM @ 1.675
NB @ 1.2
Socket @ 27C(80F) - 44C(111F) [Max @ 64C with Prime95]
CPU @ 12C(53F) - 53C(126F) [Max @ 54C with Prime95]
MOBO @ 25C(77F) - 30C(86F) [Max @ 32C with Prime95]
GPU @ 26C(82F) - 66C(151F)
MaxxMEM: 15.23 GB/s @ 71.2 Gain
smitty371
Wasn't happy with the previous tuned performance so I restarted and got to here...
http://rog.asus.com/realbench/show_comment.php?id=9166
Thanks for introducing me to this section on the site for this bench, chrsplmr
