I bought some new ram sticks, replacing my old 2x8 GB sticks with 4x8GB sticks.
Problem: I have only worked on overclocking my i7 2700k cpu earlier some time ago, and I have no idea how to overclock my ram.
Another problem: I made a few attemps, but the machine wouldn't boot.
So, everything is running happily at 1600MHz now, however I want to try up the frequencey on the ramsticks.
If I simply switch from 1600 to 1866MHz in the bios, with either 1.35V or 1.5V in the XMP settings, the machine doesn't post and keep turning itself off and on. And I have to flip the power switch on the PSU off and on, to have the machine boot back into the bios (at least I get it booting again).
With XMP set to 1.5V, I also tried setting the ram voltage to 1.5 manually, but that didn't help.
The new ram sticks are DDR3 "Crucial Ballistix Tactical LP", 8-8-8-24 timings (1600MHz), 1.35V
Did I perhaps miss some obvious setting for overclocking my ram frequency? If I have to tweak it somewhere, I have really no idea. I did not expect to run into any issue, going from 1600 to 1866MHz.
Alot of the CPU settings is currently running mostly on auto, with the cpu running at 4.6GHz.
