Maximus VIII Hero Big Difference Between CPU VID and CPU Core
Feng_Io
I am a fairly novice builder so I apologize if I am doing something silly/have a silly question. I am configuring a VIII Hero motherboard with i5-6600K and am very concerned about the voltages. Namely the values I set in BIOS seem to be largely ignored and there is a rather large gap between CPU Core and VID when the system is running.
So starting at the default BIOS values all I changed was the voltage mode. I set it manually to 1.2, booted up (win10 if that has an impact), and checked CPU-Z (ROG Version) and HWMonitor. At idle I see anywhere between .02-.1 additional value for VCore (1.22v to 1.3v). At load I see a deeply concerning 1.35v being set of VCore. I thought maybe I had a bad chip so I checked the CPU VID. As I understand it this is the voltage the cores are requesting and here I see much more reasonable values well below 1.2v.
Am I just confused about what these numbers and terms mean? Do I have some setting in BIOS set incorrectly? The .1-.2v difference between VID and VCore is freaking me out a little. In addition I can't seem to fix the peak voltage supplied correctly in order to setup the OC. Any help would be greatly appreciated.
Edit: I did some more experimenting: It seems I am missing something major as I seem to have no control at all over VCore. I set BIOS value to manual at 1.25 and increased the multiplier. When I stress the CPU the VCore jumps to rather scary 1.4V. I double checked I am on latest BIOS v401 and all the monitors tools are up to date and supposedly support this platform.
6 REPLIES 6
Raja
Don't use CPU-Z to check Vcore on this platform. It needs an update. If you are setting Vcore manually (manual mode), the Vcore is close to VID.
I checked the VCore value with CPU-Z, HWMonitor, and Aida64. Are they all broken? If so, is there a tool I should be using? Thanks for taking a look.
AI Suite is correct. That is assuming you are setting manual voltage correctly as well.
Thanks for letting me know. It seems that Aida64 values agree with AI Suite 3 so my issues aren't purely tool related. As for setting it correctly, all I did was start from the default BIOS (updated to 401) and change the "CPU Core/Cache Voltage" from "Auto" to "Manual" and set the override value. Did I leave something out?
While the manual and offset mode are still giving me problems adaptive seems to be working fine atleast when I specify the offset value too. Now VCore closely follows VID, and gap is much more reasonable: 0.03-0.05v. The plan was to switch to Adaptive after stress testing; guess I just have to remember to not stick to RealBench for that (to not run into AVX related voltage adjustments).
Menthol
Level 14
Have you read the overclocking guide? There is always some difference between the 2 readings, nothing to be alarmed, from the reviews I have read the voltages you state above are not that alarming, pay more attention to the core temperatures. Once the 6700K becomes more available there will be a lot more posts for this platform with owners experiances
A small difference I understand, but the differences I am seeing are rather large. Namely setting the BIOS value to manual@1.25 and then cranking up the multiplier, I see the VCore value going up to 1.4V. If I wasn't so nervous about the values I am sure I could push the gap higher. The Asus rep reply indicates maybe I shouldn't trust the VCore value. I am hoping that the tools are the issue, but I would need a way to make sure I am not pushing arbitrary voltage across the chip.
