Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    New ROGer Array
    Jul 2015
    4
    G751JY + Intel AC 7260 Issues + Replacement Card?
    Hello there! First and foremost thanks for taking the time to read this - this will be a help request.
    I've spent the past two months dealing with the poor performance from the Intel Dual Band AC 7260 that came with my G761JY-DB72.
    Background: At first, things seemed okay and I thought I could tolerate the slowness of the card as I wasn't gaming much and wasn't downloading much either. However, lately I've wanted to game and download some new games, but I'm getting only 500-750Kb/s download rates through steam and 500Kb - 3Mb fluctuated download speeds through firefox. I simply can't take this anymore.
    I've read the forums searching on here for the past few days before posting and I've tried the following to fix the AC 7260's speed issues and general issues with the G751JY:
    1. Turned on the laptop and noticed the awful warming of the display... wonderful.
    2. Windows 10 update from 8.1 failed, had to do a fresh install... yay!
    3. Finally got Windows 10 installed on the G751JY and noticed the slow download speeds. Calibrated my display and removed splendid to fix the warming issues.
    4. Compared my G75VW's speeds to the G751JY to ensure it's not my router. The G75VW gets a steady 5-7MB DL rate on steam, G751JY gets a full 500-750KB.
    5. Tried to update the AC 7260's drivers from Intel, had to system restore as the application would not run on my system. The driver would be uninstalled and Win10 would be left without a wireless network driver. Wunderbar, just wunderbar.
    6. Completely wiped Windows 10 (again) yesterday after searching these forums and noticed the guide with the proper installation order for the drivers and programs. Things seemed to be okay at about 1AM downloading some files with a 5-7MB/s speed.
    7. I noticed this afternoon to evening the slow 500-750KB/s speeds are back and nothing is fixing this.
    8. Ran ping tests on google to ensure I'm not crazy and am experiencing fluctuations in ping as well as download speeds... Google's ping test confirmed it. Every 5 pings I get a good 200-300ms series of pings.
    9. Searched forums some more, noticed a thread saying to try a regedit: add ScanWhenAssociated to HKLM/System/... It didn't work, still getting fluctuations in download speed sometimes now up to 3MB then back down to 500KB. Google ping tests show high spikes still... groups of 200-300.
    10. Searched google for AC 7260 replacement cards, can't find anything pertaining to the G751JY.
    11. Searched google for AC 7260 / DIR-645 connection issues, couldn't find anything...
    So, here I am. I'm trying, but I'm losing it. Does anyone know of a replacement card for the G751JY to get rid of this god forsaken slow connection? Or even better, has anyone found a fix for this?
    And here it is again, my system info:
    G751JY-DB72
    Windows 10 Home
    Intel Dual Band AC 7260 Wireless Card (18.12.1 Driver Install from 8/17/2015)
    ROG Guru: Green Belt Array
    Jun 2015
    17
    612
    I highly doubt its your card but we did swap a g751 card for the killer card out of a gt72 out of a users request who then admitted the intel card was better and asked us to swap it back but if you absolutely must
    http://www.amazon.com/Doubleshot-Wir...1B99R3HC2N7HRA
Name:	G751 7260 card.jpg
    3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio
    New ROGer Array
    Jul 2015
    4
    @aeolisio, thanks for the link and the reply! I reformatted (yet again, 3rd time now) and I'm running steam downloading the witcher 3 at 5.2-6.4MB/s so it can't be the card. It has to be something I'm installing that's killing the internet.
    Jun 2015
    17
    612
    You know windows 10 downloads updates in the background right? Theres some tools to disable updates you might want to try to see if thats your problem.
    New ROGer Array
    Jul 2015
    4
    Quote Originally Posted by aeolisio View Post
    Yes, I am aware. I set my Win10 to a metered connection so it'll stop. I'm thinking it's either Kaspersky, Networx, or VMWare that's causing the issue! Or one of the Win10 updates themself.
    New ROGer Array
    Aug 2015
    1
    I'm surprised that I have (almost) the same problem as yours and about to create a thread. Despite all the solutions I tried to find, I still can't figure out why. So would also like to request for help, if anyone can figure this out.
    Here's my issue:
    1. The wifi on my ROG G751JT (with G-sync) was running half of the speed (20-25MB according to speedtest.net) while my 2008 MacBook runs at 50-55MB full speed.
    - I've tried to connect my ROG through ETHERNET which runs solidly at 50-55 MB. So there must be something wrong with my ROG's wifi.
    - I've tried the regedit thingy [#9] which helps with my ping rate to become lower, but the wifi speed is still the same.
    - Removed GamingFirst III and McAfee and still no luck.
    - I've updated the intel wifi driver, yet the speed is still the same.
    - Searched google but no results.
    Even 20-25 MB is a fast connection, but when you are used to 50MB it feels a lot slower when downloading stuff. Would thank anyone who can solve this.
    Note:
    - I've upgraded from windows 8.1 to 10 without issues.
    - I was at another location when I got my ROG (windows 8.1) and haven't compare wifi test with my MacBook for some odd reason.
    - I've thought about doing a clean install but I guess I'll wait.
    Here's my system info:
    G751JT-T7242H
    Windows 10 Home
  7. #7
    ROG Member Array
    Jun 2015
    15
    there is god many how post about thie 7260 card been completly useless, intel blams asus, asus blames intel. so are either of you going to bother fixing the issue or just ignoring us till we go away? mostly intel, but you used their card so dont pass the buck. ten year old wireless cards are far better.
    THE NAME 7260 is now considered the worst of the worst, have you any intention of even trying to fix it or do you erealise that it simply does not work?
    ten year old cards work far better, so stop ignoring the isssues.
    https://communities.intel.com/message/362536#362536
  8. #8
    ROG Guru: Yellow Belt Array
    Apr 2013
    149
    Did you ever got this resolved?
    If so... how?
  9. #9
    Mar 2015
    8
    513
    show this windows pls
  10. #10
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    This isnt the card. I have the AC 7260 or 7265 in 4 machines and it works flawlessly. Could possibly be a single card but not likely. They generally work or the dont. ASUS AC5300 router is downstairs and at the other end of the house so through floor/ceiling and 5 walls.
