08-23-2015 03:00 PM - last edited on 03-06-2024 01:38 AM by ROGBot
08-23-2015 09:50 PM
08-23-2015 11:19 PM
M11C wrote:
Looks good. I would probably have used normal tubing to give it some character.
could use some LED backlight too.
08-23-2015 10:44 PM
08-23-2015 11:17 PM
Nate152 wrote:
Definitely different, I'm diggin' it. 🙂
I'm wondering how well the fans cool if there is no space behind them to let air flow through. One thing that concerns me is dust settling over time.
08-23-2015 11:30 PM
08-23-2015 11:45 PM
Nate152 wrote:
Two inches from the wall should be enough to get sufficient air flow, have you done any tests to see what temps you're getting?
I like the fact all the cables are hidden too it's super clean looking.
08-24-2015 03:22 AM
08-25-2015 11:45 PM
