hello,
u have nearly same pc as me 🙂 i am tweaking time to time already for two weeks and i must say that for 101% 24/7 stability it is hard to reach even 4,7 GHz 😞 i can run cinebench many times, i can run aida again and again @ 4,8 GHz with something like 1,42V vcore, but when it comes to handbrake (i have to transcode 4+TB of movies from h.264 to h.265), the only absolutely stable configuration is 4,7 GHz with vcore @1,47 - 1,49V in cpuz 😞 in bios i set vcore to positive offset 0,51V... with lower vcore i had clock watchdog timeout after 1+ hour
this is of course impossible without water cooling (i use corsair h100i gtx with 100% fan speed), on my maximus viii gene i also set LLC to level 7, cpu current capability to 140%, vrm switching frequency to 500 KHz, power duty control and power phase control to extreme... may be there is still some space for tweaking, but for now i am happy with this superstable state 🙂
right now i am on intel graphics and when i try to overclock kingston hyperx predator 4x8GB@3 GHz memory (btw 3 GHz is unstable even with default cpu frequency), my screen gets black in 1G avx2 y-cruncher 😞 i will try again later with pcie graphics card
i wish you good luck and strong mind 😄
