Results 1 to 6 of 6
    New ROGer Array
    Aug 2015
    3
    G75VW Laptop won't power on anymore
    First off hello everybody, glad there's a forum dedicated to this awesome piece of hardware.
    Anyway I have a G75VW laptop that decided to not power anymore. I plug it to the power supply, no lights, nothing. I take the battery out, plug it in, press power, still nothing. But when I put the battery back in and plug the power, the green battery indicator light comes on. I press the power button, the notification lights flash briefly but no signs of it powering on appear. I've also held the power button pressed for 30+ seconds with the power supply connected, disconnected, battery in, battery out(and any combination of the two) and I've had no success.
    I figured it could be that my battery won't hold anymore charge, but wouldn't it still power on if connected to the power supply? That only leaves me thinking the mobo might be dead, but I want to make sure with you guys. Any tips?
    New ROGer Array
    Aug 2015
    3
    Bump
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Yes it should run with out the battery installed. You can have a failing power supply also. any electronics guy can tell you how much voltage and amps are out putting. You would need a Multi Meter to make these readings. The correct voltages and amps are marked on the power supply
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    New ROGer Array
    Mar 2013
    1
    Have you figured out what's going on with your laptop? Mine pretty much does the same thing. It was working fine, but then I left the room and when I came back it was off and has the same symptoms as yours after I came back.
    I took it to a laptop place, they said my power supply looked like it was shot so I got a new one to no avail. So I'm in the same boat as you.
    Have you made any progress?
    New ROGer Array
    Aug 2015
    3
    Clint I'm pretty sure it's not an issue of the power supply, rather the laptop itself.
    Mark did your power supply have an indicator light on the "brick" part? Mine always lights up when plugged to an outlet, whether it's connected to the laptop or not. I read on another forum of a guy having similar issues as us and after returning the laptop to the manufacturer (he still had warranty) they found out the motherboard was dead. I have no idea what to do with this laptop now.
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Yes the light comes on because its connected to a power source, what that doesn't tell you is since its a transformer what it is putting out. You need a Multi Meter to read that!!! Your motherboard may be dead too who knows? but it is possible to check the out put of your power block.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
Tags for this Thread
