Results 1 to 9 of 9
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    320
    I need help regarding hard drives, G750JZ boot issues
    Hi!
    So I've been in property of Asus Rog G750JZ for a year now (almost) and everything is/was fine until a month or so ago when it suddenly said boot drive cannot be found. I was like ok..? and open the back panel to remove the drive then put it back in (I have SDD for OS and I also have HDD). Then later (Today) it said that again. This time I switched places SDD with HDD and vice versa.
    So I am wondering what could be causing this issue as both drives seems to be working perfectly fine and this started happening somewhat a month ago.
    My theory is that there are some updates or programs interfering with proper work load of the drives. Maybe a corrupted update? I am clueless.
    Any help is appreciated.
    Thank you!
    Relavant info:
    CPU: i7 4700HQ
    GPU: 880M 4GB
    MEMORY: Samsung 8GB 1600Mhz
    HARD DRIVE #1: Samsung Evo 840 250GB
    HARD DRIVE #2: HGST HTS721010A9E630 1TB
    OPERATING SYSTEM: Windows 8.1 PRO 64 Bit
    All drivers and software are updated to the latest version.
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
    Oct 2014
    50
    320
    bump
    Asus Rog G750JZ
    ROG Guru: Yellow Belt Array
    Jun 2014
    12
    177
    Does the BIOS recognize the SSD, and is it first in the boot order? Are you seeing the message directly after POST, and as soon as the OS starts to load?
    Laptop: Asus G750JZ
    OS: Win10
    Oct 2014
    50
    320
    1) Yes
    2) Yes
    3) There is no post, it appears directly after the Asus logo
    4) OS doesn't load as it says OS not found.
    Asus Rog G750JZ
    Oct 2014
    50
    320
    Any other ideas anyone?
    Asus Rog G750JZ
    ROG Guru: Brown Belt Array GottiBoi55's Avatar
    Dec 2011
    22
    1,117
    Quote Originally Posted by navis995 View Post
    you may have a corrupt boot manager, does the BIOS show the OS drive as boot drive?
    Try using the Windows recovery options by hitting f9 at power on.
    Here's a web site that will help you with this process>>>>>
    eightforums-automatic startup repair windows-8/8.1
    Hope this will help you my friend?
    Good luck, and good gaming.
    GottiBoi55
    Asus
    G750JZ-DS71 Windows 10 Pro (x64)
    Intel® Core™ i7 4700HQ (2.40GHz)
    Samsung
    24GB Memory DDR3 1600 MHz SDRAM
    SanDisk
    M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
    NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
    Second Monitor: Shar
    p Aquos 32"
  7. #7
    Oct 2014
    50
    320
    Everything works fine now as I have switched the HDD with SDD. So yes it does show. But I am wondering as to why that happened in the first place and simple switch of caddies fixed the problem.
    Asus Rog G750JZ
  8. #8
    Dec 2011
    22
    1,117
    IDK.....very strange!
    Glad to hear to worked it out anyway.
    GottiBoi55
    Asus
    Samsung
    SanDisk
    p Aquos 32"
  9. #9
    Oct 2014
    50
    320
    Yeah, I would just want the reason so I don't duplicate it or prevent it from happening again.
    Asus Rog G750JZ
Tags for this Thread
