Onboard Supreme FX (Asus Z97 Pro Gamer mobo) vs Asus Xonar DG (dedicated sound card)
ghemanth
i have recently build a new pc and my Asus Z97 Pro Gamer mobo has really gooooood sound output.
i really dont have any problems with its quality but beforing building my new pc i have purchased Asus Xonar DG dedicated sound card and here im confused that which sound output is the best ? as for the range thing, dedicated sound card is really cheap one but it has its features and on other side my mobo has a good sound. very impressed with it. as both the supremeefx and asus xonar dg are from ASUS will the dedicated sound card has advantage than the onboard sound or should i stick with the onboard sound ?
Battlefield > 26d / 2k
xD
4 REPLIES 4
NemesisChild
Level 12
What kind of sound system do you have? Do you use a headset?
For the most part, you would have to be an audiophile to notice the difference.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
i have 5.1 sound system
no. i dont use headset
xD
Chino
Level 15
If you already have the Asus Xonar DG in your possession, might as well test both to see which you like more. 😉
Vlada011
Xonar DG is old PCI Sound Card... I don't know but SupremeFX 2014 is great sound card.
My SBZ barely win with some advantages on onboard SupremeFX as stronger sound from rear speakers.
