Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Member Array
    Jan 2015
    7
    Angry G771JM - "Battery Plugged in, Not Charging" after Windows 10 Upgrade
    I have had the "Battery Plugged In, Not Charging" problem since I upgraded to Windows 10. I have removed the ACPI Compliant Control Method Battery from Device Manager. I have unplugged the AC charger, shut down the laptop, removed the battery, plugged the charger back in, rebooted. Removed the ACPI device and ACPI Fixed Feature Button, shut down, reinstalled the battery, rebooted, still wont charge. I am not sure what else to do. If anyone has any ideas I would love to hear them. Thanks.
    ROG Guru: Orange Belt Array
    Mar 2015
    310
    What battery percentage are we talking about here? 95%-99% or less than 95%?
    ROG Member Array
    Jan 2015
    7
    95% at the moment but has been going down. I have had this laptop since Jan and it has always either said Fully Charged or has not had a probelm recharging if I have used the battery. Again, this has only started after the upgrade to 10.
    ROG Member Array
    Jan 2015
    7
    By the way, I am using Bios 203, I am not sure if there is a newer one, can't locate one on the support site.
    ROG Member Array
    Jan 2015
    7
    Nevermind, I let the battery run down a bit, now its charging. Does Windows 10 have different battery management than 8 had?
    ROG Guru: Green Belt Array
    Dec 2014
    32
    533
    Quote Originally Posted by heathb00 View Post
    The behavior is the same it is likely that you just didn't notice it before.
  7. #7
    Dec 2014
    25
    607
    Yeah, I think you've missed it. Laptop EC software has been working like that since the days of Windows XP...
    It's completely normal.
  8. #8
    ROG Member Array
    Jan 2015
    7
    I have 6 other laptops in my house from 4 different manufacturers. They run Win XP, 7, and 8.1. I have gone to all of them, let the battery run down slightly, 96-97%. When I plug the power supply in, all say charging. Not something I missed. Thanks.
  9. #9
    Dec 2014
    25
    607
    Just because the laptops you have on hand don't do it doesn't mean that it hasn't been a normal thing since the days of Windows XP. You "missed it" because you simply haven't owned one such laptop.
    No need to get angry.
    In any case, this is the absolute standard now so you shouldn't worry. In fact, you should worry if your battery stays at 100% often. Mine hasn't hit 100%more than maybe...twice in the 9 months I've had it and the previous 2 ASUS, 2 MSI, 2 Acer and 1 HP laptops that belonged to either me or familiy, they pretty much never hit 100% since around the middle of 2004. Some HP and Dells ones that I've enountered during that time did have the battery reach 100% as a normal thing - but the technology and idea behind it has existed for quite a while.
  10. #10
    ROG Member Array
    Nov 2014
    15
    I have the same problem but mine is 50% down how can i fix it?
