Results 1 to 9 of 9
09-05-2015 08:22 PM #1
rcarlos243 PC Specs Laptop (Model) Asus G751JT Motherboard Gigabyte X99 SOC-FORCE Processor Intel Core i7 5820k @4.5Ghz 1.28vcore Memory (part number) 16GB DDR4 2666 CL13 Quad Channel Graphics Card #1 R9 290 4GB @1150 core w/ Corsair H105 + 2x Gentle Typhoon AP15 Sound Card FiiO E17 USB AMP/DAC Monitor BenQ XL2420z 1080p 144Hz Storage #1 256GB Samsung SM951 NVMe M.2 Storage #2 960GB Crucial M500 CPU Cooler EK Supremacy Evo, 360mm HWLabs Black Ice GTX, 360mm Swiftech MCRX20-QP, Swiftech MCP655, 6x AP15's Case Phanteks Enthoo Pro Power Supply Seasonic SS-600XP2 80 Plus Platinum Keyboard Logitech G710+ Cherry MX Brown Mouse Logitech G502 Headset Philips Fidelio X2 Mouse Pad Razr HardMatt OS Windows 10 Network Router Netgear Nighthawk X6 R8000
- Join Date
- May 2014
- Reputation
- 8
- Posts
- 41
my charger port got f***** up on my G751, where can I get a replacement charger port?
I have an Asus G751JT-CH71 and it doesn't have warranty.
it still charges but the charger port got damaged and is very loose. The plastic stuff on inside the charger port got broken and only the metal parts are exposed
Where can I get a replacement charger port?
thanks.
09-05-2015 09:01 PM #2
- Join Date
- Jun 2015
- Reputation
- 17
- Posts
- 612
Search for g751 power jack or 60NB06M0-DC1020
http://www.ebay.com/itm/Asus-G751JY-...item5423260cb2
http://www.ebay.com/itm/60NB06M0-DC1...-/231609353235Last edited by aeolisio; 09-05-2015 at 09:04 PM.
3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio
09-05-2015 10:58 PM #3
- Join Date
- May 2014
- Reputation
- 8
- Posts
- 41
09-05-2015 11:04 PM #4
- Join Date
- Jun 2015
- Reputation
- 17
- Posts
- 612
Your lucky its not on the motherboard like most laptops. If you have the skill you can solder a jack on yourself.
09-05-2015 11:16 PM #5
- Join Date
- May 2014
- Reputation
- 8
- Posts
- 41
09-05-2015 11:24 PM #6
- Join Date
- Jun 2015
- Reputation
- 17
- Posts
- 612
No its complete just install it
heres a disassembly guide
http://www.laptopultra.com/guide/asu...1-disassembly/3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio
09-06-2015 01:37 AM #7
- Join Date
- Dec 2014
- Reputation
- 32
- Posts
- 533
Those seam way over priced.
http://www.asusparts.eu/en/Asus-90NB06F1-R10080 (verify with them 100% that it is the same / a compatible board)
It may take a little longer to get to you, but it is a far more reasonable price.
I suggest doing a break down first and take a good look at what has happened on the inside.
All of this is assuming you don't have accidental damage coverage on your unit. If you do file a clam.Last edited by joshindaphils; 09-06-2015 at 01:43 AM.
09-06-2015 02:33 AM #8
- Join Date
- May 2014
- Reputation
- 8
- Posts
- 41
I just found a similar looking DC Power Jack for G751JM.
Do you think this would be compatible with my G751JT?
http://www.ebay.com/itm/60NB00M0-DC1...item43dec38af4
09-06-2015 03:26 AM #9
- Join Date
- Jun 2015
- Reputation
- 17
- Posts
- 612
Why don't you call support and find out, none of us here work for asus. Personally i wouldnt gamble with it you might find out the one you order has a different diameter barrel connector and need a different power adapter brick especially those listed on the eu site he posted since none of the part numbers match at all. Call support or open it and match the numbers to the unit you have already. Google is your friend you can search just as well as anyone else it took me less than a minute to pull up those first 2.
