Results 1 to 9 of 9
    ROG Member Array
    Sep 2015
    5
    G551JM Freezing, Shutdown Problems
    So about 3 months ago i got this laptop and i will say that i do love it and had no real problems. I mean i did get a BSOD 1-2 times but it fixed itself and hasent happened again. Anyways to the point. about a few weeks (1-2) i got more problems. such as laptop will shutitself down. even if its not warm or or hot (got a cooling pad btw) and sometimes in games even old simple games my laptop would jsut freeze up drop to 1fps for 10 so seconds then resume. Gotta say it gets really annoying at times like when im playing MGTPP or even left 4 dead 2. I looked this up and seems like no one else really had this problem or answered really. So far i tried to force programs to use high performance card. I also tried to clean out vents to see if was dust blocking it or something. Also tried to update graphics drivers and stuff also. Im not really that good with computers so yeah i dint do much. Also! about the shutdown. my battery didnt die. and it happens at the times i keep my laptop plugged in. So please anyone out there can help me with my problem. I tried to contact support but no answer in over a week form them =\
    ROG Guru: Green Belt Array
    Jun 2015
    17
    611
    Try a clean install of windows 10 then youll be working with everything updated and we can rule out software problems.
    3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio
    ROG Member Array
    Sep 2015
    5
    Alright did that and still freezing up doing games. of even sitting on the desktop
    Jun 2015
    17
    611
    Clean install right with a usb where you deleted the partitions and lost everything on that drive?
    ROG Member Array
    Sep 2015
    5
    Yes, iv done this.
    Jun 2015
    17
    611
    Then your looking at a hardware issue. Have you upgraded or changed any hardware?
  7. #7
    ROG Member Array
    Sep 2015
    5
    Not at all
  8. #8
    Jun 2015
    17
    611
    RMA it none of the hardware choices are cheap, the fps is worrying but the shutdowns speak of memory or motherboard failures It sounds power related. Sorry we coulnt find a more simple solution.
  9. #9
    ROG Member Array
    Sep 2015
    5
    Bummer. Well thank you for helping me anyways.
Tags for this Thread
